Re: engine id from bottom of engine up on a lift
[Re: orange elephants]
#2511924
06/22/18 10:10 PM
06/22/18 10:10 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
can see any picture. where is the oil filter?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
#2511929
06/22/18 10:22 PM
06/22/18 10:22 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Is the oil pan flat all the way around the bottom of the motor oil pan rails or does it curve around the timing cover and at the rear of the oil pan around the rear main bearing cap? If flat it is a BB, if it curves around the front and back it is a SB
[Re: topside]
#2511932
06/22/18 10:34 PM
06/22/18 10:34 PM
Posts: 553 Chattanooga, TN
orange elephants
Chattanooga, TN
Sorry about the lack of a picture. I have been trying to post the picture and I am extremely frustrated that it won't let me do it.
[img]"C:\Users\Owner\Pictures\CARS\1960 dodge conv lr\1961 conv"[/img]
#2511942
06/22/18 10:58 PM
06/22/18 10:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Is not going to work, that address is on your computer.
Right under the window you typed your initial post in is a link called "File Manager (Total Files: 0)" click on it
a window will pop up,
click on "Browse" and got to C:\Users\Owner\Pictures\CARS\1960 dodge conv lr\1961 conv
Click on it and add file, then click on doine adding files and post
That should do it
[Re: Spaceman Spiff]
#2512032
06/23/18 02:22 AM
06/23/18 02:22 AM
Posts: 2,081 CA
crackedback
CA
can see any picture. where is the oil filter? That's the easiest way. Pass side is a SB Dr side is a BB for A and B/RB mills
