plating suggestions, clear cadium and zinc phospate #251138
03/11/09 09:29 PM
03/11/09 09:29 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
I'm thinking of doing a bulk plating on a bunch of small things here and there with a friend to split the cost.. The two types of plating I was thinking of doing are:
clear cadium (similar to zinc):
-strikers and shims
-back of heater box
-shifter mechanism under console
-hood latch
-door window mechanisms
for example
zinc phosplate (dark gray)
- front drum backing plates
- tie-rod sleeve
etc..
Any more suggestions of the top of ya'lls head.. I'd like to get everything done at once...
Cheers,
Troy
Troy
Houston Mopar Connection Club
Re: plating suggestions, clear cadium and zinc phospate [Re: hemi68charger] #251139
03/11/09 10:19 PM
03/11/09 10:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
http://a12mopar.com/yabb/YaBB.pl?num=1209002197
Actually thats not the link I expected, there was a multi page thread about correct plating floating around but I can't find it right now...
Re: plating suggestions, clear cadium and zinc phospate [Re: 1_WILD_RT] #251140
03/11/09 10:30 PM
03/11/09 10:30 PM
Houston, Tx
Houston, Tx
Hey Randy...
Thanks.. That's a good start... I remember that article, but of course, can't place my hands on it now.. So, in the meantime, I'll save this link...
Cheers.
Troy
Re: plating suggestions, clear cadium and zinc phospate [Re: hemi68charger] #251141
03/11/09 10:31 PM
03/11/09 10:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've never seen a hood latch in clear zinc
trunk latch's were
Re: plating suggestions, clear cadium and zinc phospate [Re: gtx6970] #251142
03/11/09 10:53 PM
03/11/09 10:53 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Troy, I would recommend doing clear zinc and not cadium on your parts. Cadium is more toxic and you will have a harder time getting it done and it will cost you more.
FYI.. the backside of the heater box is supposed to be bare steel
Re: plating suggestions, clear cadium and zinc phospate [Re: hemi70se] #251143
03/11/09 11:06 PM
03/11/09 11:06 PM
Houston, Tx
Houston, Tx
The local plater here has a minimum charge of $100, regardless of the plating material. So, Cad and zinc would be the same, it's just a function of what would be more appropriate on the most number of items. I could go either way, hence my question to the masses. I appreciate all of your suggestions. I can't afford to get every component plated in the exact way it was before. I'm trying to get the freshest look and most protection as possible. The rear of the heater box will be done primarily for corrosion control. As we know, once installed, one can't see it...
Troy
Re: plating suggestions, clear cadium and zinc phospate [Re: hemi68charger] #251144
03/12/09 01:09 AM
03/12/09 01:09 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Re: plating suggestions, clear cadium and zinc phospate [Re: PAINT IT BLACK] #251145
03/12/09 10:51 AM
03/12/09 10:51 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I highly recommend Eric Manuel on the board - username 3404 - to get the correct plating, done quickly and at a very reasonable cost.
Re: plating suggestions, clear cadium and zinc phospate [Re: topside] #251146
03/12/09 11:14 AM
03/12/09 11:14 AM
Houston, Tx
Houston, Tx
I was thinking of him doing my door latches. I hear he does good work. Regarding the other stuff, I would think it would be a logistic nightmare to send all I have via the post office and be out of control. Locally, I take it, I pick it up...
Troy
