Caltracs and split mono leaf install #2511077
06/20/18 10:19 PM
06/20/18 10:19 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I just bought a set of split mono leafs and caltrac bars for my cuda that I'm in the middle of installing. I put the front caltrac bar bracket on the front of the leaf spring and when I go to put the front spring hanger over the bracket, I have about 1/8" of play side to side and only three threads showing on the bolt. Is this normal? Stock factory spring hangers. I didn't tighten anything down, but I find it hard to believe that the spring hanger is meant to be cranked in until it is tight and there is no play.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511087
06/20/18 10:33 PM
06/20/18 10:33 PM
clarks summit pa
clarks summit pa
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511110
06/20/18 11:01 PM
06/20/18 11:01 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I had a local 8.5 guy who knows some of the fastest leaf spring guys in the country, first thing he did was tighten everything up...In 4 passes I went from blowing the tires off to pulling the fronts.
I did not question what he did...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511136
06/20/18 11:52 PM
06/20/18 11:52 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would not want to crush that I would give Calvert a call first thing in the morning it might be something as simple as a couple washers and a longer Bolt
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511181
06/21/18 02:03 AM
06/21/18 02:03 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
They have different length spacers. I'd call Calvert and pick up 1/8" longer spacers, or maybe try to stick a washer in there.
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511273
06/21/18 12:13 PM
06/21/18 12:13 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am with Whitedart and mopowers, call Calvert, they are my customer service hall of fame...
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511286
06/21/18 12:49 PM
06/21/18 12:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I moved my springs into the frame I also made the boxes. They were a little wide so I used washers take up the space. They've been on the car for almost ten years with no issues.
Is the bolt in the photo short or just the way the photo was taken? I used grade 8 fine thread bolts and nylocks.
Re: Caltracs and split mono leaf install [Re: 73cuda340] #2511396
06/21/18 04:53 PM
06/21/18 04:53 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Once tightened, there should be roughly 1/16" of side gap, as so nothing binds and can pivot freely. The bolt looks to be a bit short in the pic.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Caltracs and split mono leaf install [Re: johnnycuda] #2511448
06/21/18 06:52 PM
06/21/18 06:52 PM
clarks summit pa
clarks summit pa
I called calvert and they said that it is normal; 1/16" side gap as posted earlier. The bolt in the picture is the same length as the factory bolt. I just grabbed some bolts that are 1/2" longer to replace those.
