Does this look ok? 489 Center? #251098
03/11/09 08:54 PM
03/11/09 08:54 PM
USA
Suregrip391 Offline OP
USA
I found a 3:55 chunk for my 8 3/4, it has a 489 case. Having never owned a 489 I wanted to know if this one looked damaged? It looks like its dented in to the lower right of the casting number. Is this normal? Or damaged? My 742 does not look like that. Sorry for the dumb question but just making sure its not junk...LOL
Re: Does this look ok? 489 Center? [Re: Suregrip391] #251099
03/11/09 09:07 PM
03/11/09 09:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is normal for '72-'74 489 casting third-members.
Re: Does this look ok? 489 Center? [Re: Suregrip391] #251100
03/11/09 09:08 PM
03/11/09 09:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pick at it ?
That doesn't look good ., but nothing a little jb weld won't fix ...
Re: Does this look ok? 489 Center? [Re: DoctorDiff] #251101
03/11/09 09:12 PM
03/11/09 09:12 PM
USA
USA
Does the MS number on the gear tell the date?
Re: Does this look ok? 489 Center? [Re: Suregrip391] #251102
03/11/09 09:14 PM
03/11/09 09:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no I'm pretty sure that number will match a number stamped on the stem of the pinion , pick that broken looking section and maybe you will be able to see it .
what concerns me is the part number on that gear , thats way to early a number to be a 489 gear ... I think ... I have a 3.55 gear set down stairs I can look at .
Re: Does this look ok? 489 Center? [Re: Suregrip391] #251103
03/11/09 09:15 PM
03/11/09 09:15 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The date is to the right. It is partially visible in the picture (2...).
The indention is part of the casting on the later 489 third-members.
Re: Does this look ok? 489 Center? [Re: JohnRR] #251104
03/11/09 09:17 PM
03/11/09 09:17 PM
USA
USA
Thank you, if you can look at it that would be great. Any help appreciated.
Re: Does this look ok? 489 Center? [Re: Suregrip391] #251105
03/11/09 09:27 PM
03/11/09 09:27 PM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
when it comes to rears do yourself a favor and listen to drdiff and no one else. Pete
Re: Does this look ok? 489 Center? [Re: JohnRR] #251106
03/11/09 10:13 PM
03/11/09 10:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just looked at the gears , the MS # ??? it's not on the pinion stem . The date is there as Dr. diff says , its after the MS number , I see a 2 and then a 1 . the part number is correct , I forgot the ring gear doesn't care what housing it is in , it's the same ring gear they have been making since they started making 3.55's for 8 3/4 rears .
Oh wait , I'm not dr. diff and it appears he is the ONLY person ON the planet that knows ANYTHING about the 8 3/4 rear ... my bad .
Re: Does this look ok? 489 Center? [Re: JohnRR] #251107
03/12/09 04:57 AM
03/12/09 04:57 AM
USA
USA
Thank you all for the help! Everyone, much appreciated~
Re: Does this look ok? 489 Center? [Re: Suregrip391] #251108
03/12/09 05:02 AM
03/12/09 05:02 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
a dented cast iron housing? I didn't know cast iron could dent! I would imagine it would crack before denting!
**Photobucket sucks**
Re: Does this look ok? 489 Center? [Re: 70Cuda383] #251109
03/12/09 05:21 AM
03/12/09 05:21 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what happened to the good doctors website?
I enjoyed looking on there and dreaming of parts I cannot afford right now!
Re: Does this look ok? 489 Center? [Re: JohnRR] #251110
03/12/09 09:16 AM
03/12/09 09:16 AM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
Obviously he is the only one who knows. Pete
Re: Does this look ok? 489 Center? [Re: pete] #251111
03/12/09 12:31 PM
03/12/09 12:31 PM
Thats why i use Moser ONLY!!!...
Re: Does this look ok? 489 Center? #251112
03/13/09 01:31 AM
03/13/09 01:31 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Its not a dent persay but a dimple, and I have seen them on numerous 489 cases. The one in the pic looks to have a crack in it though.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Does this look ok? 489 Center? [Re: G-Money1320] #251113
03/13/09 01:50 AM
03/13/09 01:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The crack appears to be dried mud packed into the casting dimple.
Re: Does this look ok? 489 Center? [Re: DoctorDiff] #251114
03/13/09 08:06 AM
03/13/09 08:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
which is why I asked if he picked at it ....
Re: Does this look ok? 489 Center? [Re: JohnRR] #251115
03/13/09 03:49 PM
03/13/09 03:49 PM
USA
USA
Hi Guys, sorry...No I have not picked at it. This is something I am buying and the seller sent me pics. I just did not want to buy something that was cracked or damaged. When I get it here, I will have a look and see. Thanks for the postings...It was a big help!
