How do I test a ballast resistor? #2510823
06/20/18 02:17 PM
06/20/18 02:17 PM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
I have a buddy working on a 1968 Dodge pickup. He brought me the ballast resistor and asked if there is a way to test it. I told him I knew where there was a smart group of people to ask. Thanks
2011 Drag Pak Challenger
Re: How do I test a ballast resistor? [Re: rickseeman] #2510825
06/20/18 02:18 PM
06/20/18 02:18 PM
BDW Offline
BDW  Offline
It's just a resistor, measure with an ohm meter to make sure it's not open
Re: How do I test a ballast resistor? [Re: rickseeman] #2510827
06/20/18 02:19 PM
06/20/18 02:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They can measure fine cold and fail hot
Don't be the exception.
Re: How do I test a ballast resistor? [Re: rickseeman] #2510834
06/20/18 02:31 PM
06/20/18 02:31 PM
It is a wire wound resistor, 1968 had points so it should be around .5 ohms cold scope It will change under a load so it will read with more voltage when under a load cold than it will when it warms up, it doesn't take long for them to heat up scope
Re: How do I test a ballast resistor? [Re: rickseeman] #2510898
06/20/18 04:46 PM
06/20/18 04:46 PM
Rick did he mention a specific issue? My last point ballast measured 1.6 ohms cold
Re: How do I test a ballast resistor? [Re: rickseeman] #2510903
06/20/18 04:52 PM
06/20/18 04:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The 68 FSM shows 0.5-.06 ohms for all applications listed.
Assuming it's still a stock 68 ignition system.
Re: How do I test a ballast resistor? [Re: RapidRobert] #2510920
06/20/18 05:37 PM
06/20/18 05:37 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
He said it wouldn't start and thought it was an ignition issue. I told him I didn't think it was because of the ballast resistor. (Even though I've forgotten what it does exactly.)
Re: How do I test a ballast resistor? [Re: rickseeman] #2510930
06/20/18 05:51 PM
06/20/18 05:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The ballast should be bypassed when in start.
It is only used in run.
Did he check to see if the coil had any voltage in start?
Re: How do I test a ballast resistor? [Re: rickseeman] #2510969
06/20/18 06:41 PM
06/20/18 06:41 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
I will tell him to check that.
Re: How do I test a ballast resistor? [Re: rickseeman] #2511364
06/21/18 03:37 PM
06/21/18 03:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Weigh it?
Sorry, I couldn't resist. laugh2
