How do I test a ballast resistor?
#2510823
06/20/18 02:17 PM
06/20/18 02:17 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have a buddy working on a 1968 Dodge pickup. He brought me the ballast resistor and asked if there is a way to test it. I told him I knew where there was a smart group of people to ask. Thanks
2011 Drag Pak Challenger
Re: How do I test a ballast resistor?
[Re: rickseeman]
#2510827
06/20/18 02:19 PM
06/20/18 02:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They can measure fine cold and fail hot
[Re: rickseeman]
#2510898
06/20/18 04:46 PM
06/20/18 04:46 PM
RapidRobert
Rick did he mention a specific issue? My last point ballast measured 1.6 ohms cold
[Re: rickseeman]
#2510903
06/20/18 04:52 PM
06/20/18 04:52 PM
Supercuda
About to go away
About to go away
up yours
The 68 FSM shows 0.5-.06 ohms for all applications listed.
Assuming it's still a stock 68 ignition system.
[Re: RapidRobert]
#2510920
06/20/18 05:37 PM
06/20/18 05:37 PM
rickseeman
Stuttgart, Arkansas
Rick did he mention a specific issue? My last point ballast measured 1.6 ohms cold He said it wouldn't start and thought it was an ignition issue. I told him I didn't think it was because of the ballast resistor. (Even though I've forgotten what it does exactly.)
[Re: rickseeman]
#2510930
06/20/18 05:51 PM
06/20/18 05:51 PM
Supercuda
About to go away
About to go away
up yours
The ballast should be bypassed when in start.
It is only used in run.
Did he check to see if the coil had any voltage in start?
[Re: rickseeman]
#2511364
06/21/18 03:37 PM
06/21/18 03:37 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Weigh it? Sorry, I couldn't resist.
