air cleaners #2510462
06/19/18 06:11 PM
06/19/18 06:11 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
hello group ,I was wondering has anyone used the K&N filter pn. 60-1330 and did it affect performance any my current filters (according to frieberger) are the worst ones to use any thoughts?
Re: air cleaners [Re: moparsquid] #2510527
06/19/18 09:30 PM
06/19/18 09:30 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I would think it would only be a performance gain but that filter looks small for a V8 unless your running DQs.
Re: air cleaners [Re: moparsquid] #2510539
06/19/18 09:58 PM
06/19/18 09:58 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This may be worth a few minutes to watch.
https://www.dailymotion.com/video/x693421
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: air cleaners [Re: moparsquid] #2510543
06/19/18 10:11 PM
06/19/18 10:11 PM
jersey
Spaceman Spiff Offline
jersey
can't say without knowing what you have. stock 318? big block stroker?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: air cleaners [Re: Spaceman Spiff] #2510727
06/20/18 11:39 AM
06/20/18 11:39 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
running a 500 stkr with max xram and dual 600 holleys 580 solid cam
Re: air cleaners [Re: moparsquid] #2510740
06/20/18 11:59 AM
06/20/18 11:59 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I had a K$N filter and then switched back to a paper filter and there was no difference in how it ran. Now I use the NAPA Gold filters, which are made by WIX.
Re: air cleaners [Re: moparsquid] #2510787
06/20/18 01:15 PM
06/20/18 01:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, sucking in hot underhood air is always an improvement.
Engine dynos are not real world applications.
Don't be the exception.
Re: air cleaners [Re: moparsquid] #2510841
06/20/18 02:48 PM
06/20/18 02:48 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
was told by a friend who works with the engine masters dyno guy that these ones are good my paper ones were the worst at least 100hp loss
Re: air cleaners [Re: moparsquid] #2510848
06/20/18 03:05 PM
06/20/18 03:05 PM
When I dyno tested my old pump gas 511 C.I. six pack motor I tested it with a single stock Fram paper air cleaner, then two of them stacked and then I did the same with K&N elements and then no air cleaner base and finally with the air cleaner base. I saw a little improvement with two elements versus no elements, no where near 100 HP, maybe 3 to 6 HP gain with two elements versus one work Using the base only made some small gains also, same thing in the car at the track work
Re: air cleaners [Re: moparsquid] #2510851
06/20/18 03:12 PM
06/20/18 03:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, your friend is FOS. Go view the video Goody linked. Guess who's running the dyno? Steve Brule, the "engine masters dyno guy" you mentioned.
The only way you will see a 100hp loss with a paper filter is if you are trying to make the engine breathe thru a paper bag.
Re: air cleaners [Re: Supercuda] #2510928
06/20/18 05:51 PM
06/20/18 05:51 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
I'm running the cheep spectre brand paper element anything else has to be better I may be wrong but I thought they said (FRIEBERGER) that the small round was the number 1 worst and most restrictive and it was down by 100 hp
Re: air cleaners [Re: moparsquid] #2510933
06/20/18 05:54 PM
06/20/18 05:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Watch the video and it will answer your question with eyes on proof.
Re: air cleaners [Re: moparsquid] #2510944
06/20/18 06:07 PM
06/20/18 06:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You know what, I'm FOS. I went back a re-rewatched it and the worse was a tiny filter, down 145hp or so.
Re: air cleaners [Re: moparsquid] #2510974
06/20/18 06:47 PM
06/20/18 06:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That and the plugged up mopar snorkel at -95.8.
Re: air cleaners [Re: Supercuda] #2510979
06/20/18 06:54 PM
06/20/18 06:54 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
that's the ones I'm using the small cheep ones
Re: air cleaners [Re: moparsquid] #2511001
06/20/18 07:34 PM
06/20/18 07:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, when you breathe thru a straw you ought to expect problems.
Re: air cleaners [Re: moparsquid] #2511033
06/20/18 08:47 PM
06/20/18 08:47 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I'm surprised how much was gained with dual snorkel over single snorkel.
Also, while power gains are achieved with K&N, what's left out is how much dirt they let thru. I'll stick with my paper filters.
Facts are stubborn things.
Re: air cleaners [Re: moparsquid] #2511219
06/21/18 09:05 AM
06/21/18 09:05 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Wish they would have tested an un-silenced one.
