How to remove clear overspray on windshield #2509368
06/16/18 04:21 PM
06/16/18 04:21 PM
North of the Motor City
DartGTDan Offline OP
Had the hood, scoops & cowl painted "gloss black" and my painter apparently got some clear overspray on my windshield. How do I remove the overspray?
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509370
06/16/18 04:25 PM
06/16/18 04:25 PM
A727Tflite Offline
A727Tflite  Offline
Try a razor.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509383
06/16/18 05:11 PM
06/16/18 05:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
0000 steel wool works, too, but don't use it on mirror glass, and blow off or wash off the steel wool residue.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509390
06/16/18 05:41 PM
06/16/18 05:41 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If still pretty fresh, a rag with lacquer thinner should work. Be very careful not to spill any on or touch the rag on the fresh paint.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509395
06/16/18 06:01 PM
06/16/18 06:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Spray brakleen or spray carb cleaner on a rag will take it off too.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509475
06/17/18 12:45 AM
06/17/18 12:45 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
or polishing compound
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509545
06/17/18 10:40 AM
06/17/18 10:40 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
They make a clay called overspray clay from Meguires. Designed to lift off light overspray and not cause consequential damage.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509797
06/17/18 11:53 PM
06/17/18 11:53 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Glass cleaner and a brand new razor blade.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509802
06/18/18 12:20 AM
06/18/18 12:20 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've used a regular clay bar on glass with good results.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509817
06/18/18 12:50 AM
06/18/18 12:50 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Take a single edge razor blade, mark one side, use that side up and polish it against a piece of glass with edge on glass, apply pressure, rotate in circular motion. Your blade is now honed and will clean glass with no damage.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2509850
06/18/18 07:28 AM
06/18/18 07:28 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I would start with the least aggressive and proceed thru the scale getting more aggressive if needed. Light overspray I used a polish or compound.
Keep old mopars alive.
Re: How to remove clear overspray on windshield [Re: 2boltmain] #2509861
06/18/18 09:27 AM
06/18/18 09:27 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
can you take it back to the painter?
Re: How to remove clear overspray on windshield [Re: mgoblue9798] #2510187
06/18/18 10:30 PM
06/18/18 10:30 PM
IN
ahy Offline
ahy  Offline
IN
Lacquer thinner has worked for me before. As mentioned be careful. Keep the can of thinner far away and put a small amount - finger size - on a fresh rag to remove the overspray. That way you will not damage the paint.
A razor blade used carefully is good also... especially on edges where you don't want lacquer thinner to hurt rubber or paint.
Re: How to remove clear overspray on windshield [Re: DartGTDan] #2510575
06/19/18 11:14 PM
06/19/18 11:14 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
In my shop we use a foam type window cleaner, lots of it and a razor blade
