new 440 source heads #2510443
06/19/18 05:23 PM
06/19/18 05:23 PM
Finally a HUSKER again
Moparnut426 Offline OP
So ive read the newer heads from source are a lot better than before, can anyone confirm this? just going on my mild 434 for my Bee.....
Seriously going to be a very decent lil street car I don't need anything HIGH END....
KAsey
Re: new 440 source heads [Re: Moparnut426] #2510447
06/19/18 05:35 PM
06/19/18 05:35 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Do you mean the Super Stealths, or mean that the newer Stealths are better than the initial ones released?
I have a pair of Stealths, bought last Fall. I bought the upgraded retainers and locks- and had my machinist inspect them. Everything was good: the valve job, the guide clearances, the installed valve heights and so on. Other than needing to be COMPLETELY cleaned of aluminium shavings and the 10 degree retainer upgrade (the 7 degree ones are tin..), they appear to be very well made.
Time will tell, once I get them on my motor.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: new 440 source heads [Re: Moparnut426] #2510459
06/19/18 06:02 PM
06/19/18 06:02 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
are they still cast from the low grade alloy that you cant weld on?
Re: new 440 source heads [Re: EWJ] #2510461
06/19/18 06:05 PM
06/19/18 06:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
All these heads, 440source, Sidewinder, ProMaxx and others are sure a big improvement over stock cast iron to start with. Add in the the fact they come with 11/32 stainless valves, bronze guides, new springs, flow better than stock, lighter, new, and several other reasons you can’t go wrong. All of the above listed heads can flow 300 cfm and up pretty easily.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: new 440 source heads [Re: pittsburghracer] #2510468
06/19/18 06:30 PM
06/19/18 06:30 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Never had any problems with to ones I got when they first came out or the ones I got this winter.
The only Carbs I care about are under the hood!
Re: new 440 source heads [Re: Moparnut426] #2510477
06/19/18 06:53 PM
06/19/18 06:53 PM
great, I have the better retainers, and locks already. Ill order up a set then.
thanks guys
Re: new 440 source heads [Re: Moparnut426] #2510611
06/20/18 12:29 AM
06/20/18 12:29 AM
Saskatchewan, Canada
barracudabob Offline
Does anyone have the part numbers for the ten degree locks and retainers? Thanks in advance, Bob
Re: new 440 source heads [Re: barracudabob] #2510666
06/20/18 03:36 AM
06/20/18 03:36 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
They’re listed right on the source website.....
Regarding the op: My stealth heads are 9 years old now. Never one problem, I haven’t regretted buying them for a moment. For a budget friendly street head, you’re not going to beat the value.
Re: new 440 source heads [Re: Moparnut426] #2510729
06/20/18 11:43 AM
06/20/18 11:43 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The factory appearing aspect of the stealth heads is a clever idea, but is of zero importance to me.
For the extra $90....... I’d buy the better flowing E Street heads, which come with perfectly usable hardware, and flow better ootb.
The 84cc version is straight plug.
Re: new 440 source heads [Re: Moparnut426] #2510763
06/20/18 12:34 PM
06/20/18 12:34 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I have a set I bought in 2012, they looked good also, but also had alot of shavings in them (lots in the guides).
It is worth noting, last time I had the intake off I pulled the threads on 2 of the bolts torquing it down. I have had intakes on and off 4 or 5 times over the past few years, but that was disappointing. Could be self inflicted, I don't think I could ever find a recommended intake torque spec from 440Source.
Re: new 440 source heads [Re: fast68plymouth] #2510767
06/20/18 12:38 PM
06/20/18 12:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I don't like the look of unpainted aluminum heads on a Mopar with the exception of an all aluminum Hemi, and also find the factory appearing aspect of the heads overrated.
I was surprised though that 99.9% of the people who have ever looked under my hood (and that's a lot of people) never notice that my aftermarket Hemi Orange painted Indy EZ's are not stock. Only a few knowledgeable Mopar fanatics have ever noticed them.
Re: new 440 source heads [Re: Moparnut426] #2510999
06/20/18 07:34 PM
06/20/18 07:34 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I have mine airbrushed in the peeling paint and rust patina.
Have a great day
Iowan
"obsolete is neat"
Re: new 440 source heads [Re: Iowan] #2511005
06/20/18 07:47 PM
06/20/18 07:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Seriously?!
I've always wanted to do a nasty looking stroker engine with dirt, rust and grime in a beater 4 door to take people's money!
'63 Dodge 330
11.19 @ 121 mph
Re: new 440 source heads [Re: jbc426] #2511021
06/20/18 08:14 PM
06/20/18 08:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By jbc426
[quote=fast68plymouth]
SAME!
People don't know, and they don't care.
A lot of people look under the hood of my car as well. Of course I have a factory air cleaner and manifolds, but everyone asks if it is stock (after running an 11.70) and they are surprised when I tell them its a 500 inch motor with Eddy ported aluminum heads. Amazing what a little turquoise paint will do.
Heck, probably 1/3 of the people ask if its a hemi, and it has 440 badging all over the place. shruggy
Re: new 440 source heads [Re: fast68plymouth] #2511028
06/20/18 08:30 PM
06/20/18 08:30 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
X2
So far so good on the 75cc version with angled plugs
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: new 440 source heads [Re: Moparnut426] #2511232
06/21/18 10:02 AM
06/21/18 10:02 AM
an8sec70cuda Offline
Noone ever realizes my hemi is all aluminum w/ a KB block until I tell them. Never liked the all aluminum look myself...prefer some orange under the hood.
I even had people at the track think my Indy headed 440 was a small block. shruggy It was actually smaller at 446" than some of the small blocks I've raced, lol.
Like everyone else said, if you paint the heads, I doubt anyone will even notice they aren't factory. Unless you go to the Mopar Nats or Carlisle, but then you'll get ripped apart for the plug wires not being date coded. laugh2
CHIP
'06 GMC 2500HD LBZ Duramax
Re: new 440 source heads [Re: Moparnut426] #2511795
06/22/18 04:05 PM
06/22/18 04:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive had my Stealths on since they first came out.Did change the springs ,locks,and retainers.The ones that came would have worked with a milder cam.I run a .588 solid and dome pistons.My machinist did clean the seats a bit only because he was a perfectionist and was impressed with them.Still going stron and no problems.Rocky
Chrysler Firepower
