Air filters #2510121
06/18/18 08:13 PM
06/18/18 08:13 PM
ohio
slomoshun Offline OP
ohio
What is best racing air filter besides k&n and I don’t want to have to clean and re oil This will be on a 800plus hp engine. Thanks in advance
Re: Air filters [Re: slomoshun] #2510130
06/18/18 08:33 PM
06/18/18 08:33 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Not sure about 800hp, but the Wix racing air filters are bad ass. K&N is very over rated in my opinion.4
Re: Air filters [Re: slomoshun] #2510180
06/18/18 10:17 PM
06/18/18 10:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Lot of guys use K&N without oil. Less restrictive, just trying to keep the big stuff out. Lots of different sizes and configurations available if you have an unusual space to get it in. Wix racing are also fine.
Re: Air filters [Re: slomoshun] #2510218
06/18/18 11:37 PM
06/18/18 11:37 PM
Washington
skrews Offline
skrews  Offline
Washington
X3 for WIX race filters
Re: Air filters [Re: slomoshun] #2510264
06/19/18 02:04 AM
06/19/18 02:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I threw and gave away my K&N crap and run WIX paper racing filters WAY better and less restrictive...........
Re: Air filters [Re: slomoshun] #2510271
06/19/18 02:44 AM
06/19/18 02:44 AM
AndyF Offline
AndyF  Offline
The NASCAR boys use 16 x 3 air cleaners and they are making around 800 hp. Might as well use what they use. WIX makes 16 x 3, 16 x 3.5 and 16 x 4. Use the biggest one that fits.
Re: Air filters [Re: slomoshun] #2510288
06/19/18 08:00 AM
06/19/18 08:00 AM
jersey
Spaceman Spiff Offline
jersey
Curious as to why the wix racing filter says “ no for highway use”
Is it just a disclaimer, or do these no actually filter well enough for a street driven vechile, that would see more dirty air, then a track car?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Air filters [Re: Spaceman Spiff] #2510304
06/19/18 09:52 AM
06/19/18 09:52 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We are running a WIX racing air filter with a K&N top. Works well. It's only a 3" filter. Anything taller blocks my vision. The engine makes approximately 800 hp The car has been 8.70's @ 155 That is with a mechanical throttle stop at the pedal turned out so we are only getting about 3/4 throttle.
I dont think the filter is restricting anything. I am sure the car would be in the 8.50's at WOT
Re: Air filters [Re: Spaceman Spiff] #2510370
06/19/18 01:38 PM
06/19/18 01:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, they filter big chunks, birds and other flying objects and you can see through em BUT, the 3" will flow 1000+ cfm and beyond........
Re: Air filters [Re: Thumperdart] #2510374
06/19/18 01:46 PM
06/19/18 01:46 PM
I've dyno tested two different 440 motors on two different dyno testing the 14 inch K&N filter tops, both motors lost 8 HP with them on in the dyno room confused
At the track with a air cleaner that the metal top was close to the back of the hood scoop the car picked up .03 ET and .2 MPH on back to back test at LACR years ago work up
Re: Air filters [Re: slomoshun] #2510408
06/19/18 03:09 PM
06/19/18 03:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I used an 11x5 K&N velocity stack base style assembly inside the hood scoop with an isolator plate. Didn't hurt it. I think it helped it. I don't think I would run one without an air cleaner anymore and K&N makes a lot of different sizes, shapes, panel filters, etc, that you can get a filter on just about anything. If a 14 or 16 x 3 or 4 round unit will work, you have more choices.
Re: Air filters [Re: slomoshun] #2510517
06/19/18 08:57 PM
06/19/18 08:57 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I know they make special air filters such as the oval ones for 6 pac and the multiple carb units but can a round filter be made oval without causing total loss of filtering. Lets say 16" round to 13" -14" wide oval.
Re: Air filters [Re: slomoshun] #2510518
06/19/18 08:59 PM
06/19/18 08:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I use the Wix racing filter with a pre wrap .
