Straightening a power steering pump pulley #2509561
06/17/18 11:41 AM
06/17/18 11:41 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I recently bought this Saginaw power steering pump online and when the guy shipped it he didn't put any packing material in the box. Of course, the box got thrown around during shipping and as a result the pulley got bent. I never tried straightening a pulley before so I was wondering if it is even possible to straighten the pulley straight enough or would I be better off just trying to find a replacement pulley? The pulley is the three spoke type pulley, not the solid.
Re: Straightening a power steering pump pulley [Re: 6PAX] #2509569
06/17/18 12:12 PM
06/17/18 12:12 PM
PA
70Duster Offline
70Duster  Offline
PA
Find a replacement pulley.
Re: Straightening a power steering pump pulley [Re: 6PAX] #2509832
06/18/18 02:05 AM
06/18/18 02:05 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Those spoked pulleys bent easy. Mount the pump in a vice and bend the pulley and spin it until it runs true. I have done this to a few pulleys over the years with no problems
The only Carbs I care about are under the hood!
Re: Straightening a power steering pump pulley [Re: 6PAX] #2509894
06/18/18 10:48 AM
06/18/18 10:48 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
440 source used to sell them
Mancini Racing has them , key way with locknut
http://www.manciniracing.com/postpu.html
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Straightening a power steering pump pulley [Re: 6PAX] #2510019
06/18/18 02:59 PM
06/18/18 02:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Those pulleys are expensive! I'd be pissed. For that money I'd try straightening it first. Your not out anything if you can't get it straight. Can you contact the seller and get some of your money back? I assume it was straight before he shipped it? Did you get any "before shipping" pictures of it?
Re: Straightening a power steering pump pulley [Re: burdar] #2510031
06/18/18 03:30 PM
06/18/18 03:30 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Yes, they are expensive. They cost more than I paid for the entire pump assembly. The pulley was straight before shipping. Like I said, the seller didn't put any packing material in the box and you know how the shipping companies handle packages. This isn't the first time I have bought something and the seller hasn't used any packing materials and the part(s) arrived damaged. You'd think it was a major expense to at the least pack the box with some balled up newspaper or something similar. The edge of the pulley actually ripped a hole in the side of the box. I did let the seller know and he did give me some money back. I guess I will try straightening it as suggested by Azzkikrcuda and see how straight I can get it. If I can't get it straight maybe I will be able to find one at the Nats.
