get me up to small block speed #2508897
06/15/18 02:01 PM
06/15/18 02:01 PM
Fort Collins, CO
justintyme Offline OP
Fort Collins, CO
Hi guys.
Just bought a 78 Super Coupe with a 360, so after 20 plus years of playing with big blocks, and owning all kinds of Mopar engines this is actually my first small block.
So what are the most up to date books or such that would help me out, stuff like building strokers, and La and magnum parts interchange etc
Re: get me up to small block speed [Re: justintyme] #2508902
06/15/18 02:10 PM
06/15/18 02:10 PM
Atlanta, GA
mgoblue9798 Online content
mgoblue9798  Online Content
Atlanta, GA
For a basic teardown and rebuild book for LA small block
"How to rebuild your small block Mopar"
"How to modify your Mopar Magnum" for magnum style engine and parts
Honestly there is not much new with the small block stuff. It has mostly all been done with a lot of tried and true builds already posted here.
Best advice is to post what type of build you want to do and you will get some good advice from this forum.
Re: get me up to small block speed [Re: justintyme] #2508908
06/15/18 02:22 PM
06/15/18 02:22 PM
Fort Collins, CO
Fort Collins, CO
I just like having the books to read thru, I will be definitely asking questions here of course.
Re: get me up to small block speed [Re: justintyme] #2508914
06/15/18 02:29 PM
06/15/18 02:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Like someone said above if you list a target ET, type of car and app weight, street, street-strip,drag only, budget, type of fuel you are planning to use, and your location we can head you in the right direction.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: get me up to small block speed [Re: justintyme] #2509106
06/15/18 09:33 PM
06/15/18 09:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, pick your level of insanity or addiction, and there's plenty of enabling info here, haha...
Re: get me up to small block speed [Re: justintyme] #2509144
06/15/18 10:39 PM
06/15/18 10:39 PM
I would suggest a 4" cast crank (they're cheap these days) & NO ONE who has ever stroked a SB has regretted it. KB 356 pistons. EQ mag heads with the LA intake bolt pattern. The Don Taylor basic rebuild manual is cheap second hand on eBay & after being on SB's for decades I still refer to it on occaision. The Jim Sylagi (sp) stroker book is OK but has quite a lot of high dollar info that I will never use but it does have some good info in it. Achieve quench (.035"-.040")
Re: get me up to small block speed [Re: justintyme] #2509186
06/16/18 12:27 AM
06/16/18 12:27 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I went through a similar situation about ten years ago, and like you, I enjoy having the books as a reference to thumb through on occasion.
One I really enjoyed reading was a SA Design CarTech book called "How to Build Big-Inch Mopar Small Blocks" by Jim Szilagyi.
I would also suggest reading DJVCuda's awesome build thread in the best of moparts/tech archive. It's an absolute masterpeice, both for content and entertainment.
430" small block build
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: get me up to small block speed [Re: MoparBilly] #2509204
06/16/18 01:40 AM
06/16/18 01:40 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Welcome to the club this will help get you up to Small Block speed.. https://youtu.be/tGCH74BU4FM
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: get me up to small block speed [Re: justintyme] #2509213
06/16/18 03:03 AM
06/16/18 03:03 AM
Fort Collins, CO
Fort Collins, CO
Thanks guys, got a couple books ordered and will be back once I have some time with the car and asses the engine in it. It's a 78 Super Coupe, basically a one year version of the Aspen (F Body) with heavy duty suspension, an e58 360, and a cool paint job with blacked out hood, roof and bumper, they only made 531 of them.
Re: get me up to small block speed [Re: justintyme] #2509218
06/16/18 03:28 AM
06/16/18 03:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
But does it have the factory CB radio.... that’s what we really want to know!
Re: get me up to small block speed [Re: justintyme] #2509607
06/17/18 02:04 PM
06/17/18 02:04 PM
Fort Collins, CO
Fort Collins, CO
No, No T-tops either. But it is still 70's Discosuperrific
Re: get me up to small block speed [Re: justintyme] #2509899
06/18/18 11:01 AM
06/18/18 11:01 AM
an8sec70cuda Offline
Unless those particular books are different than the big block and hemi books I see talked about all the time, save your money. If you have even a basic knowledge of engine building, you'll scan through those books once and never pick them up again.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: get me up to small block speed [Re: J_BODY] #2509914
06/18/18 11:42 AM
06/18/18 11:42 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Speaking of these, can the antenna cable ends be fixed? I want to use one in my van ( out of an Imperial)
Re: get me up to small block speed [Re: cudaman1969] #2510972
06/20/18 06:44 PM
06/20/18 06:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they can.. I fixed one of my sets.. make sure it
is clean when soldering doesnt take much heat
wave
