Re: get me up to small block speed
[Re: justintyme]
#2508914
06/15/18 02:29 PM
06/15/18 02:29 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Like someone said above if you list a target ET, type of car and app weight, street, street-strip,drag only, budget, type of fuel you are planning to use, and your location we can head you in the right direction.
[Re: justintyme]
#2509144
06/15/18 10:39 PM
06/15/18 10:39 PM
RapidRobert
I just like having the books to read thru, I would suggest a 4" cast crank (they're cheap these days) & NO ONE who has ever stroked a SB has regretted it. KB 356 pistons. EQ mag heads with the LA intake bolt pattern. The Don Taylor basic rebuild manual is cheap second hand on eBay & after being on SB's for decades I still refer to it on occaision. The Jim Sylagi (sp) stroker book is OK but has quite a lot of high dollar info that I will never use but it does have some good info in it. Achieve quench (.035"-.040")
[Re: justintyme]
#2509186
06/16/18 12:27 AM
06/16/18 12:27 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I just like having the books to read thru, I will be definitely asking questions here of course. I went through a similar situation about ten years ago, and like you, I enjoy having the books as a reference to thumb through on occasion. One I really enjoyed reading was a SA Design CarTech book called "How to Build Big-Inch Mopar Small Blocks" by Jim Szilagyi. I would also suggest reading DJVCuda's awesome build thread in the best of moparts/tech archive. It's an absolute masterpeice, both for content and entertainment. 430" small block build
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: justintyme]
#2509899
06/18/18 11:01 AM
06/18/18 11:01 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Unless those particular books are different than the big block and hemi books I see talked about all the time, save your money. If you have even a basic knowledge of engine building, you'll scan through those books once and never pick them up again.
[Re: J_BODY]
#2509914
06/18/18 11:42 AM
06/18/18 11:42 AM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
But does it have the factory CB radio.... that’s what we really want to know! Speaking of these, can the antenna cable ends be fixed? I want to use one in my van ( out of an Imperial)
[Re: cudaman1969]
#2510972
06/20/18 06:44 PM
06/20/18 06:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
But does it have the factory CB radio.... that’s what we really want to know! Speaking of these, can the antenna cable ends be fixed? I want to use one in my van ( out of an Imperial) Yes they can.. I fixed one of my sets.. make sure it is clean when soldering doesnt take much heat
