E body variable wipers won't Park #2508343
06/14/18 12:46 PM
06/14/18 12:46 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
When I turn the wipers off they stop right where they are, instead of parking themselves in the concealed position. Anyone know why?
Thanks.
Re: E body variable wipers won't Park [Re: ragtop] #2508366
06/14/18 01:29 PM
06/14/18 01:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I got a wife like that, I give up figuring her out and just live with it.
Don't be the exception.
Re: E body variable wipers won't Park [Re: ragtop] #2508378
06/14/18 01:44 PM
06/14/18 01:44 PM
My 1994 van wipers do the same thing (park vertical/far left).
Re: E body variable wipers won't Park [Re: ragtop] #2508407
06/14/18 02:31 PM
06/14/18 02:31 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Jules had a video on youtube that showed how to troubleshoot that. Usually was a ground issue.
Re: E body variable wipers won't Park [Re: ragtop] #2508423
06/14/18 02:55 PM
06/14/18 02:55 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Poor ground for the motor housing. Try a jumper wire from case to battery.
Angry white pureblood male
Re: E body variable wipers won't Park [Re: ruderunner] #2508480
06/14/18 05:11 PM
06/14/18 05:11 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Could also be the switch ground or the motor internal switch the get a little corrosion on them and cease to work.
I have a motor check document that can be used without removing the motor
Contact me if you need it.
Somerbr1@aol.com
Ns1aar.com
NS1AAR
Re: E body variable wipers won't Park [Re: ragtop] #2509016
06/15/18 05:49 PM
06/15/18 05:49 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Like others have noted, check condition of the various grounds. Many times with everything being painted we forget about things needing to be grounded. Also make sure your wiper switch inside the car has a good ground. With that said the problem I found with mine was inside the wiper motor. There is what amounts to a set of breaker points under the black, round cover on the wiper motor. Remove the 5 screws holding the black cover down. Note the clocking of the cover with tape or a pencil mark. Gently lift off the cover. On the underside of the cover you'll find these "breaker points". If you have a small flat file, clean the contact points. I suppose sandpaper would work as well. Reassemble the cover onto the wiper body and reinstall the screws. I did this with the wiper motor on the car. Between the grounding and cleaning the contact points, it fixed alot of problems I was having with the wiper motor, including the park feature.
1972 Dodge Challenger
Re: E body variable wipers won't Park [Re: PLUM_72] #2509151
06/15/18 10:47 PM
06/15/18 10:47 PM
^^^ good info, I'm gonna open mine up!
