1970 Cuda trunk lock #2508117
06/13/18 08:47 PM
06/13/18 08:47 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Been looking to purchase ignition, door and trunk locks for my 70 Cuda. I see a lot on Whew Bay and some kits indicate the trunk lock will not work for Cuda. Is there something specific about the Cuda trunk lock? Some sellers say theirs fit 70-71 models and some say 70-72 models. Looking for some guidance and thanks.
Re: 1970 Cuda trunk lock [Re: gregok] #2508123
06/13/18 09:03 PM
06/13/18 09:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The offset lock requires a long rod that may not be included in the 'fits all' kits.
Re: 1970 Cuda trunk lock [Re: gregok] #2508147
06/13/18 10:01 PM
06/13/18 10:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes the lock cylinder is specific for the lever to attach with an E clip.
Re: 1970 Cuda trunk lock [Re: Alaskan_TA] #2508179
06/13/18 11:14 PM
06/13/18 11:14 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I do have the correct long rod, just the lock had no tumblers. So the kits don’t provide the long rod is why they say it won’t work on the 70 Cuda?
Re: 1970 Cuda trunk lock [Re: gregok] #2508225
06/14/18 01:05 AM
06/14/18 01:05 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The arm/lever that attaches to the lock (held on with a c clip) is a lot longer on a 70/71. You can use a standard trunk lock and switch the arm/lever if you already have it. The trunk latch is also unique for 70/71's because of the lever for the long rod.
Re: 1970 Cuda trunk lock [Re: gregok] #2508356
06/14/18 01:18 PM
06/14/18 01:18 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
How can you use a standard trunk lock? They don't have the same connections on the back for an arm and E clip.
You could swap the tumblers from a donor to your original lock.
Re: 1970 Cuda trunk lock [Re: gregok] #2508509
06/14/18 06:30 PM
06/14/18 06:30 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Look at the differences
This is a ABC trunk lock. Notice how the link attaches
70 Barracuda trunk cylinder and linkage, held on with an E clip. Notice hole in lever
1970 Barracuda trunk latch and lever. Notice the hole in lever is different from e lock cylinder.
Re: 1970 Cuda trunk lock [Re: NANKET] #2508626
06/14/18 11:49 PM
06/14/18 11:49 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks Nanket, that helps a lot.
