#2508117 - 06/13/18 06:47 PM 1970 Cuda trunk lock
gregok Offline
Loc: Oklahoma
Been looking to purchase ignition, door and trunk locks for my 70 Cuda. I see a lot on Whew Bay and some kits indicate the trunk lock will not work for Cuda. Is there something specific about the Cuda trunk lock? Some sellers say theirs fit 70-71 models and some say 70-72 models. Looking for some guidance and thanks.
#2508123 - 06/13/18 07:03 PM Re: 1970 Cuda trunk lock [Re: gregok]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Moredoor, PA
The offset lock requires a long rod that may not be included in the 'fits all' kits.
#2508147 - 06/13/18 08:01 PM Re: 1970 Cuda trunk lock [Re: gregok]
NANKET Offline
Loc: northwest USA
Yes the lock cylinder is specific for the lever to attach with an E clip.
#2508179 - 06/13/18 09:14 PM Re: 1970 Cuda trunk lock [Re: Alaskan_TA]
gregok Offline
Loc: Oklahoma
I do have the correct long rod, just the lock had no tumblers. So the kits don’t provide the long rod is why they say it won’t work on the 70 Cuda?
#2508225 - 06/13/18 11:05 PM Re: 1970 Cuda trunk lock [Re: gregok]
NV69B7RR Offline
Loc: Reno, Nevada
The arm/lever that attaches to the lock (held on with a c clip) is a lot longer on a 70/71. You can use a standard trunk lock and switch the arm/lever if you already have it. The trunk latch is also unique for 70/71's because of the lever for the long rod.
68 AMX track car
72 Demon 340
71 Duster 340 Resto http://board.moparts.org/ubbthreads/show...part=1&vc=1
#2508356 - 06/14/18 11:18 AM Re: 1970 Cuda trunk lock [Re: gregok]
NANKET Offline
Loc: northwest USA
How can you use a standard trunk lock? They don't have the same connections on the back for an arm and E clip.
You could swap the tumblers from a donor to your original lock.
#2508509 - 06/14/18 04:30 PM Re: 1970 Cuda trunk lock [Re: gregok]
NANKET Offline
Loc: northwest USA
Look at the differences
Description: This is a ABC trunk lock. Notice how the link attaches
Description: 70 Barracuda trunk cylinder and linkage, held on with an E clip. Notice hole in lever
Description: 1970 Barracuda trunk latch and lever. Notice the hole in lever is different from e lock cylinder.
#2508626 - 06/14/18 09:49 PM Re: 1970 Cuda trunk lock [Re: NANKET]
gregok Offline
Loc: Oklahoma
Thanks Nanket, that helps a lot.
25,351 Registered Members
190,317 Topics
Intake bottom "pan" or "plate"
by DUFFMAN
06/24/18 04:08 PM
Any Mopar fanatics live in or near Ottawa Canada?
by Moparpete
06/24/18 04:06 PM
1971 Charger R/T fender tag question
by Purestocker
06/24/18 03:54 PM
SSBP discs: No room for grease cups
by General 68
06/24/18 01:46 PM
