Can using cheap oil filters cause low/high oil pressure ? #2506782
06/10/18 09:08 PM
06/10/18 09:08 PM
Penna
70satelliteguy Offline OP
Penna
This is on a Big block.
Normally don't have a problem but stuck a cheaper auto parts store filter on this time.
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2506790
06/10/18 09:35 PM
06/10/18 09:35 PM
Washington
madscientist Offline
Washington
Yes. I won't run anything with Fram on it.
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2506792
06/10/18 09:46 PM
06/10/18 09:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Go to napa and get a Wix or Napa Gold. Cheap insurance
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: pittsburghracer] #2506896
06/11/18 01:56 AM
06/11/18 01:56 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What is your engine worth to you??Cheap is CHEAP! You get what you pay for!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: hemi-itis] #2507016
06/11/18 12:28 PM
06/11/18 12:28 PM
moparx Online content
moparx  Online Content
i have personally had cheapy filters collapse internally, causing low flow and pressure issues. luckily, no permanent damage, but cheap is CHEAP ! wix, or napa gold [wix] for me, but there are other quality filters out there such as baldwin. absolutely NO FRAM !
beer
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507046
06/11/18 01:39 PM
06/11/18 01:39 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
filter1.com and use discount code MOPARTS. They sell WIX free shipping over $50.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: moparx] #2507048
06/11/18 01:46 PM
06/11/18 01:46 PM
dogdays Offline
dogdays  Offline
An oil pump is a positive displacement pump. That means it pumps a certain volume per revolution. The pressure it develops is due to the restriction in the flow out of the pump.
IF the filter were to block or impede flow, the pressure that the pump sees would increase. Whether your oil pressure gauge registers high or low depends on where in the oil system the gauge is mounted.
R.
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507111
06/11/18 03:40 PM
06/11/18 03:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
On a street car, Wix/NAPA Gold, Mobil 1 on occasion, K&Ns are OK too I think. On a race motor, I look at the micron rating to see how restrictive it is. I don't use daily driver filters on race engines. Used System 1 on my stuff for years. Love them.
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507134
06/11/18 04:19 PM
06/11/18 04:19 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I would recommend a system one oil filter. Billet housing so it will not burst, filter element is cleanable, and it makes it easy to check on bearing material when you change your oil, plus you will never buy another oil filter.
http://www.system1filters.com/
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507460
06/12/18 11:16 AM
06/12/18 11:16 AM
hemi-itis Offline
hemi-itis  Offline
Had this on the shelf for 20 years,just plain for got I had it 'till I dug out the aluminum fueler heads I recently installed whistling spank
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: jwb123] #2507535
06/12/18 03:05 PM
06/12/18 03:05 PM
All of the system one housing I've seen, including the one in your picture, have cast housings, not billet tsk
I'm not sure that makes any difference when it comes to burst strengths of either type material though work shruggy
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507542
06/12/18 03:26 PM
06/12/18 03:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
We had the short System One on a 90* adapter, tucked up beside the engine on my small blocks, no extra plumbing. Tube chassis deal. My next oil filter will be the Clear View Filtration unit. Check it without being taken apart.
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: CMcAllister] #2507605
06/12/18 06:14 PM
06/12/18 06:14 PM
Penna
Penna
"My next oil filter will be the Clear View Filtration unit. Check it without being taken apart"
Wow , who sells them?
Just changed my oil and I got a Wix on it now!!!
Mike
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507627
06/12/18 07:01 PM
06/12/18 07:01 PM
PA.
"Little"John
"Little"John
PA.
Mike
Wait till you hear the price on this one. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507649
06/12/18 07:50 PM
06/12/18 07:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been wanting to use a remote mount filter and the clearview has crossed my mind. It would be nicer to see it in the window on a casual glance rather than waiting on it to show up on your drain plug. It is a little on the pricey side though or I would already have it.
68 Barracuda Formula S 340
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: 70satelliteguy] #2507654
06/12/18 08:08 PM
06/12/18 08:08 PM
A727Tflite Offline
A727Tflite  Offline
Clear view makes both cast and billet.
EDIT: meant to say System makes them. Sorry.
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: pittsburghracer] #2507694
06/12/18 09:26 PM
06/12/18 09:26 PM
jersey
Spaceman Spiff Offline
jersey
Mike
Still cheaper than replacing an engine
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: Spaceman Spiff] #2507708
06/12/18 10:10 PM
06/12/18 10:10 PM
PA.
"Little"John
"Little"John
PA.
Mike
I never had that issue with a Wix or Napa Gold so I guess I'm ahead of the game.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can using cheap oil filters cause low/high oil pressure ? [Re: pittsburghracer] #2507820
06/13/18 08:17 AM
06/13/18 08:17 AM
jersey
jersey
Mike
I didn’t mean it filters any better. I meant, if you have some metal in the oil, you can see it between rounds, or wh3never you look at the filter, without any work. Don’t have to drain the oil, or cut a filter open, to catch a problem.
