Special starter stud?
#2507243
06/11/18 09:21 PM
06/11/18 09:21 PM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am putting a smallblock engine and 998 torqueflite together, and went to mount the starter. The upper hole in the starter is .620 diameter ( too small to accept a 5/8),the bolt hole in the trans case is 7/16 threaded bolt hole. The lower hole in the starter is 7 /16 and matches what is in the trans case. What am i missing hear? I am not sure where this starter came from, it is a new style small starter. Do i have the wrong starter? Do i need a special stud?
Re: Special starter stud?
[Re: gregsdart]
#2507254
06/11/18 09:48 PM
06/11/18 09:48 PM
dartman366
Mt. Vernon, Ohio
sounds like the hole in the starter (.620) is sized for a metric bolt 12mm maybe, thats even too small for a 5/8 bolt
[Re: dartman366]
#2507259
06/11/18 09:54 PM
06/11/18 09:54 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
are you sure on the bolt size? both the upper and lower bolt/stud on mine are 7/16 dia. with a 5/8 head/nut.
[Re: Mr340]
#2507271
06/11/18 10:12 PM
06/11/18 10:12 PM
dartman366
Mt. Vernon, Ohio
are you sure on the bolt size? both the upper and lower bolt/stud on mine are 7/16 dia. with a 5/8 head/nut. now that you mention it you are right, it should be a 7/16 bolt/stud not 5/8 I stand corrected.also their is normally a stud with 7/16 coarse that screws into the bell and the other end is 7/16 fine thread for a nut and washer
[Re: gregsdart]
#2507294
06/11/18 10:45 PM
06/11/18 10:45 PM
gregsdart
I never gave it much thought before. Is it oversized to allow a little room for things being off a bit? .180 oversized is a bunch though. I went to an auto parts store and the picture looks like what i have?
[Re: gregsdart]
#2507334
06/11/18 11:55 PM
06/11/18 11:55 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have an old Nippondenso laying here and the upper hole is about 5/8. The snout of the starter in the bore in the trans is what locates and supports the starter.
[Re: CMcAllister]
#2507347
06/12/18 12:17 AM
06/12/18 12:17 AM
gregsdart
I have an old Nippondenso laying here and the upper hole is about 5/8. The snout of the starter in the bore in the trans is what locates and supports the starter. Thanks. Looks like i am just overthinking it.
[Re: gregsdart]
#2507361
06/12/18 01:01 AM
06/12/18 01:01 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Between three cars big blocks and small blocks, powerglides and Matt’s 727 almost all of my starters are modified. One setup I had to open up the one bolt hole for the stud on my adapter plate. Several I have to cut the nose off all together. Whatever it takes to work
[Re: gregsdart]
#2507362
06/12/18 01:03 AM
06/12/18 01:03 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I ran into the same thing last fall on my starter. As stated above the nose locates the starter and the bolt/stud just hold it in place. I couldn't see that much being correct so I made bushings to fit 7/16.
[Re: gregsdart]
#2507398
06/12/18 02:53 AM
06/12/18 02:53 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Greg I have never had a problem using 7/16 bolts and letting the mini starter center on the recess in the bell housing with my smallblock/904 stuff
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2507412
06/12/18 07:17 AM
06/12/18 07:17 AM
Posts: 9,835 MI, usa
dvw
MI, usa
Greg I have never had a problem using 7/16 bolts and letting the mini starter center on the recess in the bell housing with my smallblock/904 stuff Same here with my BB/727. 6 years 500+ passes. Doug
