Special starter stud?
#2507243
06/11/18 09:21 PM
06/11/18 09:21 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am putting a smallblock engine and 998 torqueflite together, and went to mount the starter. The upper hole in the starter is .620 diameter ( too small to accept a 5/8),the bolt hole in the trans case is 7/16 threaded bolt hole. The lower hole in the starter is 7 /16 and matches what is in the trans case. What am i missing hear? I am not sure where this starter came from, it is a new style small starter. Do i have the wrong starter? Do i need a special stud?
Re: Special starter stud?
[Re: gregsdart]
#2507254
06/11/18 09:48 PM
06/11/18 09:48 PM
dartman366
Mt. Vernon, Ohio
sounds like the hole in the starter (.620) is sized for a metric bolt 12mm maybe, thats even too small for a 5/8 bolt
[Re: dartman366]
#2507259
06/11/18 09:54 PM
06/11/18 09:54 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
are you sure on the bolt size? both the upper and lower bolt/stud on mine are 7/16 dia. with a 5/8 head/nut.
[Re: Mr340]
#2507271
06/11/18 10:12 PM
06/11/18 10:12 PM
dartman366
Mt. Vernon, Ohio
are you sure on the bolt size? both the upper and lower bolt/stud on mine are 7/16 dia. with a 5/8 head/nut. now that you mention it you are right, it should be a 7/16 bolt/stud not 5/8 I stand corrected.also their is normally a stud with 7/16 coarse that screws into the bell and the other end is 7/16 fine thread for a nut and washer
[Re: gregsdart]
#2507294
06/11/18 10:45 PM
06/11/18 10:45 PM
gregsdart
I never gave it much thought before. Is it oversized to allow a little room for things being off a bit? .180 oversized is a bunch though. I went to an auto parts store and the picture looks like what i have?
[Re: gregsdart]
#2507334
06/11/18 11:55 PM
06/11/18 11:55 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have an old Nippondenso laying here and the upper hole is about 5/8. The snout of the starter in the bore in the trans is what locates and supports the starter.
[Re: CMcAllister]
#2507347
06/12/18 12:17 AM
06/12/18 12:17 AM
gregsdart
I have an old Nippondenso laying here and the upper hole is about 5/8. The snout of the starter in the bore in the trans is what locates and supports the starter. Thanks. Looks like i am just overthinking it.
[Re: gregsdart]
#2507361
06/12/18 01:01 AM
06/12/18 01:01 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Between three cars big blocks and small blocks, powerglides and Matt’s 727 almost all of my starters are modified. One setup I had to open up the one bolt hole for the stud on my adapter plate. Several I have to cut the nose off all together. Whatever it takes to work
[Re: gregsdart]
#2507362
06/12/18 01:03 AM
06/12/18 01:03 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I ran into the same thing last fall on my starter. As stated above the nose locates the starter and the bolt/stud just hold it in place. I couldn't see that much being correct so I made bushings to fit 7/16.
[Re: gregsdart]
#2507398
06/12/18 02:53 AM
06/12/18 02:53 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Greg I have never had a problem using 7/16 bolts and letting the mini starter center on the recess in the bell housing with my smallblock/904 stuff
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2507412
06/12/18 07:17 AM
06/12/18 07:17 AM
Posts: 9,848 MI, usa
dvw
MI, usa
Greg I have never had a problem using 7/16 bolts and letting the mini starter center on the recess in the bell housing with my smallblock/904 stuff Same here with my BB/727. 6 years 500+ passes. Doug
[Re: ss/la]
#2507724
06/12/18 10:57 PM
06/12/18 10:57 PM
gregsdart
on the nip nipondenso starter just move the stud to the upper hole on the trans you will be fine. mother mopar reversed the holes on later model vehicles Done!
