trunk floor drain hole size question
#250732
03/11/09 01:59 PM
03/11/09 01:59 PM
Ok, since dad and I are presently working on the trunk section of our 70 chally vert, we noticed that the floor did not have the drain holes cut out when the previous owner had the trunk floor replaced. We have a general location of where all the holes go, but we do not know what the hole saw size that we need should be.
Can anyone help us with some measurements?
Thanks,
Brian
Re: trunk floor drain hole size question
[Re: Snoopy]
#250735
03/11/09 06:46 PM
03/11/09 06:46 PM
Snoopy,
Thanks for the diagram. That oval hole at the very bottom, is that the hole for cudas for the filler tuber? Also, can you point out which ones are 3/4" as the 1" and 3/4" circles seem to be a bit close in size when I printed the diagram out.
Thanks again for your help.
Brian
[Re: Snoopy]
#250738
03/11/09 09:05 PM
03/11/09 09:05 PM
Snoopy, You're too good to me.
