trunk floor drain hole size question #250732
03/11/09 01:59 PM
03/11/09 01:59 PM
Ok, since dad and I are presently working on the trunk section of our 70 chally vert, we noticed that the floor did not have the drain holes cut out when the previous owner had the trunk floor replaced. We have a general location of where all the holes go, but we do not know what the hole saw size that we need should be.
Can anyone help us with some measurements?
Thanks,
Brian
Re: trunk floor drain hole size question [Re: ] #250733
03/11/09 02:21 PM
03/11/09 02:21 PM
Wisconsin
Mopar Mark Offline
Mopar Mark  Offline
Wisconsin
If you do a search for (challenger trunk floor hole location), you will find what you need. Member "Snoopy" uploaded a chart for a Cuda trunk floor for me in that topic. Cuda and Challenger trunk floor holes are same except gas filler tube location.
1970 Challenger R/T 440-4 Auto 2000 Ram Quad Cab 4x4 360 Auto 1973 Dodge 1/2 ton 4x4 318 Auto 1995 Dodge Dakota 4x4 318 Auto
Re: trunk floor drain hole size question [Re: ] #250734
03/11/09 03:03 PM
03/11/09 03:03 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Hope this helps.
Re: trunk floor drain hole size question [Re: Snoopy] #250735
03/11/09 06:46 PM
03/11/09 06:46 PM
Snoopy,
Thanks for the diagram. That oval hole at the very bottom, is that the hole for cudas for the filler tuber? Also, can you point out which ones are 3/4" as the 1" and 3/4" circles seem to be a bit close in size when I printed the diagram out.
Thanks again for your help.
Brian
Re: trunk floor drain hole size question [Re: ] #250736
03/11/09 07:48 PM
03/11/09 07:48 PM
Snoopy Offline
Snoopy  Offline
Try this. If anyone sees any mistakes, please point them out so I can make this as accurate as possible. There is only one 3/4" hole and that is the fuel sending unit access hole.
6 - 1 3/4" Holes
6 - 1" Holes
1 - 3/4" Hole
4 - 1/4" Holes
Re: trunk floor drain hole size question [Re: Snoopy] #250737
03/11/09 08:36 PM
03/11/09 08:36 PM
Snoopy Offline
Snoopy  Offline
Reproduction 70 Challenger Trunk Pan
Re: trunk floor drain hole size question [Re: Snoopy] #250738
03/11/09 09:05 PM
03/11/09 09:05 PM
Snoopy,
You're too good to me.
Re: trunk floor drain hole size question [Re: ] #250739
03/11/09 09:35 PM
03/11/09 09:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I do not see the hole for the license plate light wire?
Photos are from a 1970 Challenger, I do not know if they are the same for a Barracuda.
The hole in this one is 31/64;
Re: trunk floor drain hole size question [Re: Alaskan_TA] #250740
03/11/09 09:36 PM
03/11/09 09:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: trunk floor drain hole size question [Re: Alaskan_TA] #250741
03/11/09 09:37 PM
03/11/09 09:37 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: trunk floor drain hole size question [Re: Alaskan_TA] #250742
03/11/09 11:48 PM
03/11/09 11:48 PM
Snoopy Offline
Snoopy  Offline
Barry,
The Barracuda doesn't have that hole.
Re: trunk floor drain hole size question [Re: Snoopy] #250743
03/12/09 11:57 AM
03/12/09 11:57 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Good to know, thanks!
Where is it on the Barracuda then? Tailpanel?
Re: trunk floor drain hole size question [Re: Alaskan_TA] #250744
03/12/09 01:29 PM
03/12/09 01:29 PM
Snoopy Offline
Snoopy  Offline
The harness goes across the bottom of the rear panel and then goes up and over the lock housing. The license plate light sits above the license plate.
