Evans Waterless Coolant #2507097
06/11/18 03:27 PM
06/11/18 03:27 PM
WV
K
KZ4406 Offline OP
KZ4406  Offline OP
K
WV
Does anyone have any experience with this product?
https://www.evanscoolant.com/products/
Re: Evans Waterless Coolant [Re: KZ4406] #2507125
06/11/18 04:04 PM
06/11/18 04:04 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
yup. It’s amazing when you pay 40 bucks a gallon how many gallons it takes to fill a 440 and a 3 core 26” radiator. I believe I’ve put 6.5 in it. It’s good stuff from what I hear. I’ll let you know how my car performs once I get the bugs out and can actually drive the thing.
I’m listening.
Re: Evans Waterless Coolant [Re: Big Bad Bee] #2507148
06/11/18 04:52 PM
06/11/18 04:52 PM
dogdays Offline
dogdays  Offline
Bulk propylene glycol can be had for less than $20 per gallon plus tax and freight.
Evans Coolant is mainly propylene glycol plus a little ethylene glycol plus anticorrosion package.
R.
Re: Evans Waterless Coolant [Re: KZ4406] #2507218
06/11/18 07:57 PM
06/11/18 07:57 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have had original formula Evans NPG in my 1995 Magnum 5.9V8 since 1998.
It does work as far as cooling. It does not transfer as much heat as water.
It did not reduce pinging via what Evans “nucleate boiling”.
An engine idling at a coolant temperature of 260 degrees is quite smooth compared to either 195 or 205.
You can take the fan blades off and run for months during seasons where AC is not needed.
Around year 2003 my drivers side plastic radiator side tank began leaking and I replaced the original radiator. I am not sure whether the Evans NPG caused this.
The Evans NPG changes color over time. Evans says not to worry.
Re: Evans Waterless Coolant [Re: KZ4406] #2507248
06/11/18 09:35 PM
06/11/18 09:35 PM
jersey
Spaceman Spiff Offline
jersey
had a friend that tried in in his turbo'd big block chevy powered mustang. car ran to hot for his liking, so he tried the evans coolant. flushed everything out, and put the evans in.
while it did reduce the coolant temp, it INCREASED his OIL temperature, to the point of he had to stop and pull over, and let it cool down. on one than one occasion.
i wonder how many people monitor their oil temp vs coolant?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Evans Waterless Coolant [Re: KZ4406] #2510620
06/20/18 12:46 AM
06/20/18 12:46 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
A thermostat's job is to regulate temperature. Below it's temperature it will be closed. As temperature rises it opens just enough to allow coolant to flow to the radiator. If it ever reaches wide open it's because it's asking the radiator for more cooling and the radiator is returning all it can. This scenario should never be seen, if it is you need more cooling, like a bigger radiator.
Re: Evans Waterless Coolant [Re: KZ4406] #2510649
06/20/18 02:15 AM
06/20/18 02:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Wrong. A thermostat regulates flow.
Re: Evans Waterless Coolant [Re: Kern Dog] #2510678
06/20/18 07:42 AM
06/20/18 07:42 AM
jersey
jersey
Which is how it regulates temperature.
A thermostat in your home regulates temperature by switching things on/off, an automotive thermostat does it by regulating flow.
Re: Evans Waterless Coolant [Re: KZ4406] #2510690
06/20/18 09:24 AM
06/20/18 09:24 AM
USA
3
360view Offline
360view  Offline
3
USA
When I searched parts books before the highest temperature thermostat I could find that would fit a Magnum V8 was 205 degrees F by Stant.
Does anyone know of available today 210 to 260 degree F setpoint thermostats?fr
Re: Evans Waterless Coolant [Re: KZ4406] #2510826
06/20/18 02:18 PM
06/20/18 02:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That is way too high temp to keep an engine together. Engines run more efficiently at 185-195* range. At 260 the oil thins out so bad it can't protect the bearings.
Re: Evans Waterless Coolant [Re: KZ4406] #2517156
07/03/18 07:58 PM
07/03/18 07:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
scope catfight
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Evans Waterless Coolant [Re: KZ4406] #2517321
07/04/18 09:37 AM
07/04/18 09:37 AM
Guitar Jones Offline
It's really not much different than straight antifreeze, I wouldn't spend the extra money on it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Evans Waterless Coolant [Re: Guitar Jones] #2517396
07/04/18 12:11 PM
07/04/18 12:11 PM
BlueRacer69 Offline
BlueRacer69  Offline
I agree. It cost to much. Fill it with Distilled water, a bottle of water pump lube, and 1 or 2 gallons of good anti-freeze, depending on where you live in the country.
Re: Evans Waterless Coolant [Re: stumpy] #2517403
07/04/18 12:17 PM
07/04/18 12:17 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
modern engines are designed to operate in the low 200 degree range.
Its an emissions thing
Re: Evans Waterless Coolant [Re: gtx6970] #2517417
07/04/18 12:48 PM
07/04/18 12:48 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Agree. The fans in my '99 Vette (LS-1) aren't programmed to come on till 226 degrees, and that's on low with the AC on. They come on high at 236. Not that those temps are what you want to see on an RB designed 50+ years ago. Its just that modern synthetic oils and blends aren't effected by temperatures as much as fossil oils used to be.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Evans Waterless Coolant [Re: BlueRacer69] #2517421
07/04/18 12:56 PM
07/04/18 12:56 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
:Iagree:
But if you live in an area that doesn’t get below 25 degrees and it’s garaged...
Don’t run antifreeze at all. Lousy at transferring/removing heat from motor.
Re: Evans Waterless Coolant [Re: KZ4406] #2517431
07/04/18 01:11 PM
07/04/18 01:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO ...it's like buying snake oil.
Fix whatever is causing your high temps and save your money for more important things like fixing your cooling system.
I used it years ago in a new factory fresh 454 in a dually that was doing some heavy duty towing and it made no difference.
Re: Evans Waterless Coolant [Re: KZ4406] #2517539
07/04/18 03:50 PM
07/04/18 03:50 PM
Washington
madscientist Offline
Washington
I ask the question to all who are bashing Evans coolant. Have you ever used it?
It's amazing how many guys love straight water. I can tell you straight water is a block killer. It's stupid. Even if you drain it after every race.
If you can't maintain coolant temperature with an antifreeze mix fix your cooling system.
Evans works. It doesn't build pressure or need pressure to work. That, all by itself is worth the money.
Re: Evans Waterless Coolant [Re: madscientist] #2517568
07/04/18 04:51 PM
07/04/18 04:51 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Snot snake oil. Some benefits:
1. Because of the very high boiling point, there is no need to run the system at pressure, increasing the life of parts - hoses, heater core, radiator, water pump seals.
2. Never needs replacement.
3. Eliminates water, electrolysis, cavitation.
4. Because of the very high boiling point and ability to stay liquid rather than steam, it removes more combustion chamber heat in cylinder heads than water or antifreeze-water and adds octane tolerance, ability to operate on a lower octane fuel without detonation.
Re: Evans Waterless Coolant [Re: madscientist] #2517679
07/04/18 09:36 PM
07/04/18 09:36 PM
jersey
jersey
Have you monitored oil temps with it, vs regular antifreeze/water mix?
