Re: Evans Waterless Coolant
[Re: KZ4406]
#2507125
06/11/18 04:04 PM
06/11/18 04:04 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
yup. It’s amazing when you pay 40 bucks a gallon how many gallons it takes to fill a 440 and a 3 core 26” radiator. I believe I’ve put 6.5 in it. It’s good stuff from what I hear. I’ll let you know how my car performs once I get the bugs out and can actually drive the thing.
I’m listening.
[Re: KZ4406]
#2507248
06/11/18 09:35 PM
06/11/18 09:35 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
had a friend that tried in in his turbo'd big block chevy powered mustang. car ran to hot for his liking, so he tried the evans coolant. flushed everything out, and put the evans in. while it did reduce the coolant temp, it INCREASED his OIL temperature, to the point of he had to stop and pull over, and let it cool down. on one than one occasion. i wonder how many people monitor their oil temp vs coolant?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: KZ4406]
#2510620
06/20/18 12:46 AM
06/20/18 12:46 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
A thermostat's job is to regulate temperature. Below it's temperature it will be closed. As temperature rises it opens just enough to allow coolant to flow to the radiator. If it ever reaches wide open it's because it's asking the radiator for more cooling and the radiator is returning all it can. This scenario should never be seen, if it is you need more cooling, like a bigger radiator.
[Re: Kern Dog]
#2510678
06/20/18 07:42 AM
06/20/18 07:42 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Wrong. A thermostat regulates flow. Which is how it regulates temperature. A thermostat in your home regulates temperature by switching things on/off, an automotive thermostat does it by regulating flow.
[Re: KZ4406]
#2517321
07/04/18 09:37 AM
07/04/18 09:37 AM
Guitar Jones
It's really not much different than straight antifreeze, I wouldn't spend the extra money on it.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2517396
07/04/18 12:11 PM
07/04/18 12:11 PM
Posts: 729 Michigan
BlueRacer69
It's really not much different than straight antifreeze, I wouldn't spend the extra money on it. I agree. It cost to much. Fill it with Distilled water, a bottle of water pump lube, and 1 or 2 gallons of good anti-freeze, depending on where you live in the country.
[Re: stumpy]
#2517403
07/04/18 12:17 PM
07/04/18 12:17 PM
Posts: 21,429 It's a dry heat
gtx6970
It's a dry heat
That is way too high temp to keep an engine together. Engines run more efficiently at 185-195* range. At 260 the oil thins out so bad it can't protect the bearings. modern engines are designed to operate in the low 200 degree range. Its an emissions thing
[Re: gtx6970]
#2517417
07/04/18 12:48 PM
07/04/18 12:48 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
That is way too high temp to keep an engine together. Engines run more efficiently at 185-195* range. At 260 the oil thins out so bad it can't protect the bearings. modern engines are designed to operate in the low 200 degree range. Its an emissions thing Agree. The fans in my '99 Vette (LS-1) aren't programmed to come on till 226 degrees, and that's on low with the AC on. They come on high at 236. Not that those temps are what you want to see on an RB designed 50+ years ago. Its just that modern synthetic oils and blends aren't effected by temperatures as much as fossil oils used to be.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: BlueRacer69]
#2517421
07/04/18 12:56 PM
07/04/18 12:56 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
It's really not much different than straight antifreeze, I wouldn't spend the extra money on it. I agree. It cost to much. Fill it with Distilled water, a bottle of water pump lube, and 1 or 2 gallons of good anti-freeze, depending on where you live in the country. :Iagree: But if you live in an area that doesn’t get below 25 degrees and it’s garaged... Don’t run antifreeze at all. Lousy at transferring/removing heat from motor.
[Re: KZ4406]
#2517431
07/04/18 01:11 PM
07/04/18 01:11 PM
Challenger 1
Cincinnati, Ohio
IMO ...it's like buying snake oil. Fix whatever is causing your high temps and save your money for more important things like fixing your cooling system. I used it years ago in a new factory fresh 454 in a dually that was doing some heavy duty towing and it made no difference.
[Re: KZ4406]
#2517539
07/04/18 03:50 PM
07/04/18 03:50 PM
Posts: 4,457 Washington
madscientist
Washington
I ask the question to all who are bashing Evans coolant. Have you ever used it?
It's amazing how many guys love straight water. I can tell you straight water is a block killer. It's stupid. Even if you drain it after every race.
If you can't maintain coolant temperature with an antifreeze mix fix your cooling system.
Evans works. It doesn't build pressure or need pressure to work. That, all by itself is worth the money.
[Re: madscientist]
#2517568
07/04/18 04:51 PM
07/04/18 04:51 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Evans works. It doesn't build pressure or need pressure to work. That, all by itself is worth the money. Snot snake oil. Some benefits: 1. Because of the very high boiling point, there is no need to run the system at pressure, increasing the life of parts - hoses, heater core, radiator, water pump seals. 2. Never needs replacement. 3. Eliminates water, electrolysis, cavitation. 4. Because of the very high boiling point and ability to stay liquid rather than steam, it removes more combustion chamber heat in cylinder heads than water or antifreeze-water and adds octane tolerance, ability to operate on a lower octane fuel without detonation.
[Re: madscientist]
#2517679
07/04/18 09:36 PM
07/04/18 09:36 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Evans works. It doesn't build pressure or need pressure to work. That, all by itself is worth the money. Have you monitored oil temps with it, vs regular antifreeze/water mix?
