Re: Found my limits with a full exhaust system [Re: DusterDave] #2505586
06/07/18 01:34 PM
06/07/18 01:34 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By DusterDave
First of all, turn the damned boost up! I can fart and make 6 lbs. of boost! Turn it up to at least 10 lbs. Don't worry, your motor can take it! Not sure about the driver, tho..... wink
Secondly, I doubt that you are at the limits of your exhaust system. I ran a 3-1/2" exhaust system with the 3-1/2" Hooker AeroChambers, and my best time was a problematic pass of 9.16. I'd suggest uncorking it and see what the difference is.
It’s just a pump gas street car...
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505590
06/07/18 01:49 PM
06/07/18 01:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
For what it's worth, my car is 3740lb with me in it and has been ~142mph.
On SINGLE 4" exhaust... let alone dual.
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505591
06/07/18 01:50 PM
06/07/18 01:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It does seem like the dual 4" should be enough but it for sure worth unhooking it and giving it a try.
68 Barracuda Formula S 340
Re: Found my limits with a full exhaust system [Re: Spaceman Spiff] #2505604
06/07/18 02:29 PM
06/07/18 02:29 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
So was mine. But when its at the track, it's quick and easy to swap a pulley, mix in a couple gallons of race gas, take out some timing, and let it eat. But hey, its his car.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Found my limits with a full exhaust system [Re: an8sec70cuda] #2505608
06/07/18 02:54 PM
06/07/18 02:54 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Originally Posted By an8sec70cuda
Originally Posted By 1Fast340
I dont think your limitation is from the full exhaust,more probable that you mufflers are what holds you back if anything exhaustrelated.Hooker aerochambers are not available in 4" from what i can remeber and as can bee seen in your pics you have adapators to make the 3½" mufflers fit 4" tubing.
If i where you i would try some 4" straight thru mufflers such as Borla XR1,Magnaflow,Dynatech splitflow,Hooker maxlfows. Those are what i can think of that are availble with a reasonable lenght that is ovalbody with a straight thru design that is not crimped down inside,Things may have changed since i left the exhaustbussines 5 years ago.
iagree The biggest aero chambers are 3.5". You need some straight through style mufflers. I have 4" Hooker max flows on mine now. I doubt they are any louder than the aero chambers honestly. I was surprised how quiet they are. They're cheap compared to the other brands too.
iagree I have the 4" Dynomax bullet mufflers with a full 4 inch x pipe system to the axle. Again, like others, I was surprised how quiet they were, disappointingly unloud frown
Re: Found my limits with a full exhaust system [Re: DusterDave] #2505678
06/07/18 06:41 PM
06/07/18 06:41 PM
Guitar Jones Offline
I think this is correct. 6 lbs of boost is what the factories use on the stock engines to keep them out of trouble. My Cummins will make 26 lbs and it's a stock 12 valve with just some minor pump tweaks and a single 4" exhaust. I know diesels are different but come on, 6 lbs?
Turn up the wick and let it eat! Might require some tuning though to reach the full potential.
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505710
06/07/18 07:54 PM
06/07/18 07:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If the kids 360 can run 9.55/141 at 21lbs. The hemi at 13-16 boost lbs, Ye haw. Its all about conservative timing. More boost makes more power than more timing.
Doug
Re: Found my limits with a full exhaust system [Re: Guitar Jones] #2505711
06/07/18 07:56 PM
06/07/18 07:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Turn that 12 Valve up. My stock 12 valve has been over 35 lbs for 200,000 miles.
Doug
Re: Found my limits with a full exhaust system [Re: DusterDave] #2505792
06/08/18 01:07 AM
06/08/18 01:07 AM
Great Neck,LI,new york
hemi-itis Offline OP
I turned it up to 10 lbs with improvement.It sepatated one of the slip joints.Will uncork it and see what happens At South Mountain Raceway in July!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505820
06/08/18 03:29 AM
06/08/18 03:29 AM
The last blown pump gas hemi I dyno tuned made 927 HP at 7300 RPM with 7 lbs. of boost with 33 degree timing, it was 12% undriven.
We swap the pulleys so it had 13% over drive, put in 110 octane race gas, reduced the timing to 25 degrees and that motor made 1024 HP at 6500 RPM with 12.0 lbs. of boost before going into detonation above that RPM whiney We added two degrees and it went into detonation sooner realcrazy I should have started with 22 degrees or less, probably work
What I found out later is you can make to much power on the street, even with pump gas normally asperated devil boogie up grin
Back pressure can make a heck of a lot of difference on some cars based on the pipe and muffler sizes and type used shruggy
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505908
06/08/18 01:15 PM
06/08/18 01:15 PM
If I have a 4" collector going into 4" pipe,does it matter if the cut out is after the collector or after the "X" pipe? Would going after the "x" have any benefit??
https://www.youtube.com/watch?v=Qv0Mmqwz0lw
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505913
06/08/18 01:40 PM
06/08/18 01:40 PM
Texas
RustyM Offline
RustyM  Offline
Texas
I believe being after the X with cutouts has no benefit at all, just adds a slight bit of back pressure.
How much pipe after header flange and before X?
If you have enough for the engine to "see" a 14-18 inch collector extension then dumping out, I think that would be optimum.
Just my thoughts.
Love your car btw.
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505931
06/08/18 02:23 PM
06/08/18 02:23 PM
Thank you.I wonder if collector length makes a difference with a blown application.Zoomies might work best but I street drive....alot!
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505934
06/08/18 02:36 PM
06/08/18 02:36 PM
Texas
RustyM Offline
RustyM  Offline
Texas
I think the principles remain the same when we are talking about these power levels , temps, exhaust speeds etc.
I would think someone, somewhere, has done dyno testing with blown motors and collector tuning- finding that data might be an interesting quest.
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505939
06/08/18 02:47 PM
06/08/18 02:47 PM
Texas
RustyM Offline
RustyM  Offline
Texas
It wont matter at higher boost levels but in street trim with 6 to 10 lbs boost it might be worth playing with .
Might pick up a little tq .
more boost and rpm- I think its just about getting getting exhaust out ,least amount of back pressure.
In your case, Im thinking the X pipe isn't helping and getting the cutouts in front of the X just eliminates back pressure/turbulence.
Just my thoughts.
