mopar w58 wheels #2504107
06/03/18 10:50 PM
06/03/18 10:50 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
On the buildsheet for my cuda, it lists the wheels as w58 and the color TX8. Does anybody have a picture of these wheels? I'm curious which ones they are but i cant find anything with that code.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: mopar w58 wheels [Re: 73cuda340] #2504113
06/03/18 10:59 PM
06/03/18 10:59 PM
clarks summit pa
clarks summit pa
Accidentally posted in wrong forum, could this please be moved? Thanks
Re: mopar w58 wheels [Re: 73cuda340] #2504192
06/04/18 02:51 AM
06/04/18 02:51 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the "SALES CODE" is on the bottom line of the sheet & would be
W21 - rallye wheels
the 58 you found in the "BUILD CODES" section:
#3580058 = 14x5.5" Rallye wheel
TX8 is the spare wheel paint color = "black"
55 = last 2-digits for the spare wheel assembly part # for a plain steel 14x5.5" wheel
24 = last 2-digits for the trim ring #2944424
work or do you have an "8" stamped in the "W5_ PAINTED WHEELS" section on the bottom line?? shruggy
moparts W21 Rallye wheels.jpgmoparts Rallye wheels.jpg72-73-74-cuda-challenger-14-rallye-wheels-rims-set-4.jpg
Re: mopar w58 wheels [Re: 6bblgt] #2504968
06/05/18 08:19 PM
06/05/18 08:19 PM
clarks summit pa
clarks summit pa
The only thing on the build sheet for my wheels are the ones in the build codes section with the 58, TX8 and 55. The wheel covers space next to those three has a 4, and the entire wheel/cover section at the bottom of the sheet is blank.
Re: mopar w58 wheels [Re: 73cuda340] #2505070
06/06/18 02:30 AM
06/06/18 02:30 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have the sheet from a black '73 'cuda that is missing every "2" on the entire sheet.
could be a similar problem with your sheet? how close is the VIN? got pics?
anyway, what you have decodes to 14x5.5" RALLYE wheels! up
moparts cuda 73 bs23h3b391729-bs.jpgmoparts cuda 73 sheet no 2s.jpgmoparts cuda 73 sheet no 2s W.jpg
Re: mopar w58 wheels [Re: 6bblgt] #2505078
06/06/18 04:19 AM
06/06/18 04:19 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That would really suck if you had R22
Re: mopar w58 wheels [Re: Morty426] #2505081
06/06/18 05:05 AM
06/06/18 05:05 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
per the sheet it's a '73 340 'cuda with dual exhaust & NO tips eek
Re: mopar w58 wheels [Re: 6bblgt] #2505351
06/06/18 07:23 PM
06/06/18 07:23 PM
clarks summit pa
clarks summit pa
Mine is missing all of the 2's as well. The vin is close, mine is 393953. I'll try to upload some pictures.
Re: mopar w58 wheels [Re: 73cuda340] #2505362
06/06/18 08:17 PM
06/06/18 08:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
with over 2,000 cars a day out of Hamtramck, MI - I bet they are pretty close …..
what's the sequence number upper right?
TX9 = "2"-1505?? of course missing the "2"
JA5 = "2"-15???? of course missing the "2"
Re: mopar w58 wheels [Re: 6bblgt] #2505370
06/06/18 08:43 PM
06/06/18 08:43 PM
clarks summit pa
clarks summit pa
15 blank space 645
Re: mopar w58 wheels [Re: 73cuda340] #2505375
06/06/18 09:30 PM
06/06/18 09:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Close.
If the sheets have the same font & were printed at the same station, that printer malfunction went undetected for a while.
Re: mopar w58 wheels [Re: 6bblgt] #2505381
06/06/18 09:57 PM
06/06/18 09:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
TX9 = "2"-1505?? (00-99 ??)
time stamp on line 6 = 07:46 (7:28AM)
JA5 = "2"-152645 (or are your "1"s missing also?)
2047 - 2146 cars apart on the line
what's the "time stamp" at the beginning of line 6? Do you have a door sticker? what's printed next to MDH?
Re: mopar w58 wheels [Re: 6bblgt] #2505435
06/07/18 12:12 AM
06/07/18 12:12 AM
clarks summit pa
clarks summit pa
The 1's are present, time is 0713, and mdh is 031712
Re: mopar w58 wheels [Re: 73cuda340] #2505441
06/07/18 12:29 AM
06/07/18 12:29 AM
clarks summit pa
clarks summit pa
I have pictures of the build sheet, not sure how to post them without photobucket though
Re: mopar w58 wheels [Re: 73cuda340] #2505442
06/07/18 12:31 AM
06/07/18 12:31 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
scope
Re: mopar w58 wheels [Re: 6bblgt] #2505443
06/07/18 12:40 AM
06/07/18 12:40 AM
clarks summit pa
clarks summit pa
Thanks for the help
Re: mopar w58 wheels [Re: 73cuda340] #2505445
06/07/18 12:44 AM
06/07/18 12:44 AM
clarks summit pa
clarks summit pa
date of manufacture on the fender tag is march 20, 1973
