mopar w58 wheels
#2504107
06/03/18 10:50 PM
06/03/18 10:50 PM
Posts: 1,179 clarks summit pa
73cuda340
clarks summit pa
On the buildsheet for my cuda, it lists the wheels as w58 and the color TX8. Does anybody have a picture of these wheels? I'm curious which ones they are but i cant find anything with that code.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: mopar w58 wheels
[Re: 73cuda340]
#2504113
06/03/18 10:59 PM
06/03/18 10:59 PM
73cuda340
clarks summit pa
Accidentally posted in wrong forum, could this please be moved? Thanks
[Re: 73cuda340]
#2504192
06/04/18 02:51 AM
06/04/18 02:51 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
the "SALES CODE" is on the bottom line of the sheet & would be W21 - rallye wheels the 58 you found in the "BUILD CODES" section: #35800 58 = 14x5.5" Rallye wheel TX8 is the spare wheel paint color = "black" 55 = last 2-digits for the spare wheel assembly part # for a plain steel 14x5.5" wheel 24 = last 2-digits for the trim ring #29444 24 or do you have an "8" stamped in the "W5_ PAINTED WHEELS" section on the bottom line??
[Re: 6bblgt]
#2504968
06/05/18 08:19 PM
06/05/18 08:19 PM
73cuda340
clarks summit pa
The only thing on the build sheet for my wheels are the ones in the build codes section with the 58, TX8 and 55. The wheel covers space next to those three has a 4, and the entire wheel/cover section at the bottom of the sheet is blank.
[Re: 73cuda340]
#2505070
06/06/18 02:30 AM
06/06/18 02:30 AM
6bblgt
Las Vegas, NV
I have the sheet from a black '73 'cuda that is missing every "2" on the entire sheet. could be a similar problem with your sheet? how close is the VIN? got pics? anyway, what you have decodes to 14x5.5" RALLYE wheels!
[Re: 6bblgt]
#2505078
06/06/18 04:19 AM
06/06/18 04:19 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I have the sheet from a black '73 'cuda that is missing every "2" on the entire sheet. could be a similar problem with your sheet? how close is the VIN? got pics? anyway, what you have decodes to 14x5.5" RALLYE wheels! That would really suck if you had R22
[Re: 6bblgt]
#2505351
06/06/18 07:23 PM
06/06/18 07:23 PM
73cuda340
clarks summit pa
I have the sheet from a black '73 'cuda that is missing every "2" on the entire sheet. could be a similar problem with your sheet? how close is the VIN? got pics? anyway, what you have decodes to 14x5.5" RALLYE wheels! Mine is missing all of the 2's as well. The vin is close, mine is 393953. I'll try to upload some pictures.
[Re: 6bblgt]
#2505435
06/07/18 12:12 AM
06/07/18 12:12 AM
73cuda340
clarks summit pa
TX9 = "2"-1505?? (00-99 ??) time stamp on line 6 = 07:46 (7:28AM)
JA5 = "2"-152645 (or are your "1"s missing also?)
2047 - 2146 cars apart on the line
what's the "time stamp" at the beginning of line 6? Do you have a door sticker? what's printed next to MDH?
The 1's are present, time is 0713, and mdh is 031712
[Re: 73cuda340]
#2505441
06/07/18 12:29 AM
06/07/18 12:29 AM
73cuda340
clarks summit pa
I have pictures of the build sheet, not sure how to post them without photobucket though
[Re: 6bblgt]
#2505443
06/07/18 12:40 AM
06/07/18 12:40 AM
73cuda340
clarks summit pa
Thanks for the help
[Re: 73cuda340]
#2505445
06/07/18 12:44 AM
06/07/18 12:44 AM
73cuda340
clarks summit pa
date of manufacture on the fender tag is march 20, 1973
