Found my limits with a full exhaust system #2504869
06/05/18 03:53 PM
06/05/18 03:53 PM
Great Neck,LI,new york
hemi-itis Offline OP
Made it to ATCO Sunday to race with Ralph and his SUPERCCARSERIES.We had planned on Saturday and Sunday but the weather gods did not agree.So Sunday I loaded up at 5am,met up with Dom and off we went for the almost 3 hour drive to the track.I was able to make 5 laps.The DA was good,,under 1000 but the humidity was terrible.Best ET of the day was 9.4 and best MPH was 145.
I did find the power,,,,,,or power loss from back pressure.The #7 header tube comes off the flange,,,goesover the chassis rail to a slip joint then bends back under to the collector.The back pressure separated the slip joint and beat up the ends of both tubes.My crew cheif fixed it up.bent the tubes back to together and used a self tapper to hold it in place so I was able to make 2 more passes!
https://www.youtube.com/watch?v=Bo3_KH3cRrc&index=2&list=UUTrwOIf41SToTnfSdHnx_Qg
34475247_10155854013839620_5657277419883593728_n.jpg34645096_10155854025814620_169307533498908672_n.jpg
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2504897
06/05/18 04:48 PM
06/05/18 04:48 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
What a beast! How much more do you think is left in the car e/t wise with that trap speed?
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2504941
06/05/18 07:19 PM
06/05/18 07:19 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Great Job!
Matt
Re: Found my limits with a full exhaust system [Re: mattsmopars] #2504944
06/05/18 07:22 PM
06/05/18 07:22 PM
N.Y.
sixpacksteve Offline
N.Y.
when you say full exhaust 3"? what mufflers? is there an H or X crossover?
curious!
Hell Hath No Fury Like Mine
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2504978
06/05/18 08:46 PM
06/05/18 08:46 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That wheels up pic is good . 😉
Big ole girl needs to work on her 60'
Re: Found my limits with a full exhaust system [Re: FastmOp] #2504999
06/05/18 10:15 PM
06/05/18 10:15 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Nice job getting it down the track Al. Sounds like its running OK.
Cough*time*cough cough*for a*cough*ladder bar*cough
stirthepot
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505017
06/05/18 11:12 PM
06/05/18 11:12 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Bad to the bone, I love it!
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505030
06/05/18 11:52 PM
06/05/18 11:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bring it west young man.
Doug
Re: Found my limits with a full exhaust system [Re: 1mean340] #2505074
06/06/18 03:33 AM
06/06/18 03:33 AM
I can't say without any certainly,but I would like to reach my legal limit of 8.50. It's been 9.3 @ 147 with 6 lbs of boost and intake air temp of 160*.And weighs in at 3700 lbs+ the parachute.
Re: Found my limits with a full exhaust system [Re: sixpacksteve] #2505075
06/06/18 03:41 AM
06/06/18 03:41 AM
curious!
4 inch collector going into 4 inch exhaust out the rear bumper.Hooker Aerochamber with an "X" pipe
Exhaust done by James Vignogna Performace.
https://www.facebook.com/VignognaRacingEngines
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505076
06/06/18 03:46 AM
06/06/18 03:46 AM
Can you imagine wow much exhaust pressure must be present to separate a slip joint!!!! eek
https://www.youtube.com/watch?v=Qv0Mmqwz0lw
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505080
06/06/18 04:29 AM
06/06/18 04:29 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Not trying to be a a$$. But I think you still got a ways to go to max out that killer exhaust. That joint needs a couple pop rivits.
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505117
06/06/18 10:18 AM
06/06/18 10:18 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I dont think your limitation is from the full exhaust,more probable that you mufflers are what holds you back if anything exhaustrelated.Hooker aerochambers are not available in 4" from what i can remeber and as can bee seen in your pics you have adapators to make the 3½" mufflers fit 4" tubing.
If i where you i would try some 4" straight thru mufflers such as Borla XR1,Magnaflow,Dynatech splitflow,Hooker maxlfows. Those are what i can think of that are availble with a reasonable lenght that is ovalbody with a straight thru design that is not crimped down inside,Things may have changed since i left the exhaustbussines 5 years ago.
Re: Found my limits with a full exhaust system [Re: 1Fast340] #2505125
06/06/18 10:37 AM
06/06/18 10:37 AM
an8sec70cuda Offline
iagree The biggest aero chambers are 3.5". You need some straight through style mufflers. I have 4" Hooker max flows on mine now. I doubt they are any louder than the aero chambers honestly. I was surprised how quiet they are. They're cheap compared to the other brands too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505141
06/06/18 11:20 AM
06/06/18 11:20 AM
Thanks for the tips and you are correct,they neck down to 3.5 and come back up to 4" installed 1n 2006.A friend gave me a pair of 4 inch Magna flows to try/have.I bought almost a year ago bought the material I need to make cut outs.My plan was to have them come out after the "X" and before the muffler and exit in front of the rear tire.I knew the mufflers might hurt me when installed.My best pass was with 6 lbs of boost.I moved it up to 10 lbs and it choked.The mufflers given to me have a cut out hole right in front of them.
Is there much of a difference where the cut out is? I would think as long as they are before the muffler id would be good. work
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505186
06/06/18 01:05 PM
06/06/18 01:05 PM
N.Y.
N.Y.
how difference if you ran with just open headers? or header extension?
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505253
06/06/18 03:04 PM
06/06/18 03:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Great launch pic ! Nice going. Ron
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505419
06/06/18 11:20 PM
06/06/18 11:20 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That's a bad hotrod!
Re: Found my limits with a full exhaust system [Re: sixpacksteve] #2505453
06/07/18 12:55 AM
06/07/18 12:55 AM
Never ran it open,but it's choking right now!
Re: Found my limits with a full exhaust system [Re: hemi-itis] #2505541
06/07/18 11:54 AM
06/07/18 11:54 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
First of all, turn the damned boost up! I can fart and make 6 lbs. of boost! Turn it up to at least 10 lbs. Don't worry, your motor can take it! Not sure about the driver, tho..... wink
Secondly, I doubt that you are at the limits of your exhaust system. I ran a 3-1/2" exhaust system with the 3-1/2" Hooker AeroChambers, and my best time was a problematic pass of 9.16. I'd suggest uncorking it and see what the difference is.
Gone to the dark side with an LS3 powered '57 Chevy 210
