Paint work on a Survivor?
#2504555
06/04/18 11:06 PM
06/04/18 11:06 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
There is a small area on the lower 1/4 on my survivor Demon that needs to be painted. I've taken it to 3 shops and one wants to use Chroma Base and one wants to use base coat/clear. The color is Y8. Would using a 2 stage give the affected area too much shine/gloss and not match the patina of the 47 year old paint? The paint on the car is in beautiful condition otherwise.
Re: Paint work on a Survivor?
[Re: topside]
#2504712
06/05/18 10:34 AM
06/05/18 10:34 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Y8 will be a challenge but not impossible to do with a single stage. Keep in mind the best job will still leave a ghost line in a metallic repair. The trick is to minimize it. The right amount of thinning and expanding work area in steps and blending agents can be successful.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: formula_s]
#2505161
06/06/18 12:04 PM
06/06/18 12:04 PM
Posts: 2,252 New York
rarefish
New York
There is a small area on the lower 1/4 on my survivor Demon that needs to be painted. I've taken it to 3 shops and one wants to use Chroma Base and one wants to use base coat/clear. The color is Y8. Would using a 2 stage give the affected area too much shine/gloss and not match the patina of the 47 year old paint? The paint on the car is in beautiful condition otherwise. Boy, this question sure hits home. I dealing with pretty much the same issue on my survivor 1969 Dart that is B7 blue. The drivers 1/4 panel was replaced when the car was 3 months old due to an accident. It was painted with lacquer and that paint is now shot. I was counting on a local shop that was run by some old timers to repaint the 1/4, but I just found out that they have closed up and are retiring.
[Re: Little Detroit]
#2505208
06/06/18 01:40 PM
06/06/18 01:40 PM
Posts: 6,714 KY
65pacecar
KY
in most cases an offer of more money will delay retirement, remember cash is king. I agree, and if its only a quarter panel plus blend they may be interested in it, the only problem is your warranty (if one) retires with them
[Re: formula_s]
#2505247
06/06/18 02:50 PM
06/06/18 02:50 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
These guys are all hitting home on this one. Many paints are no longer legal to buy/use (e.g. lead pigments or paints with tons of solvent).
Even if the paint "looks good" there has been "some" fading + every batch of paint (even back in 60's/70's) varied in color just a touch batch-to-batch.
Bottom line... it should be custom color matched. You can get test panels sprayed up (with an appropriate primer as close as possible to the original primer on the car) & blend several small batches to get the customer blend really, really close. Then, have someone who does custom paint work or an auto-restoration shop spray it, blending in the repair, as these guys have mentioned. That's the best you can do.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Govierjr.]
#2506664
06/10/18 04:19 PM
06/10/18 04:19 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
If possible locate the local paint supplier to the body shops in that area and see if they have access to camera that can analyze paint color on car and get a match that way.
the paint supplier's sales people should know who the painters in that area are that know what they are doing and willing to work in conjunction with you and the paint supplier to get the repair done.
I agree with the above keeping it small as possible. I assume repair area is below horizontal body line below marker lamp? Side stripes or no side stripes?
Any good shop should have the camera and their own mixing system.
[Re: AdamR]
#2506830
06/10/18 11:27 PM
06/10/18 11:27 PM
formula_s
North Pole,New York
[quote=Govierjr.]If possible locate the local paint supplier to the body shops in that area and see if they have access to camera that can analyze paint color on car and get a match that way.
Yes the area is right below the body line below the side marker light so that would be obvious area to break the new paint. Oddly , the paint scan matches to 2002 Lotus Mars Gold.
