Paint work on a Survivor? #2504555
06/04/18 11:06 PM
06/04/18 11:06 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
There is a small area on the lower 1/4 on my survivor Demon that needs to be painted. I've taken it to 3 shops and one wants to use Chroma Base and one wants to use base coat/clear. The color is Y8. Would using a 2 stage give the affected area too much shine/gloss and not match the patina of the 47 year old paint? The paint on the car is in beautiful condition otherwise.
Re: Paint work on a Survivor? [Re: formula_s] #2504563
06/04/18 11:34 PM
06/04/18 11:34 PM
MO
cdp Offline
cdp  Offline
MO
Y8 gold would be hard to match. Would probably require blending and clearing IMO, for a respectable repair. Most metallics would need a BC/CC system anyways, compared to a solid color.
Re: Paint work on a Survivor? [Re: formula_s] #2504602
06/05/18 12:30 AM
06/05/18 12:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You need to find a different shop. Contact Frank Badelson, he can give you some pointers, he does similar repairs.
Re: Paint work on a Survivor? [Re: formula_s] #2504609
06/05/18 12:39 AM
06/05/18 12:39 AM
Canada
demon Offline
demon  Offline
Canada
whatever you do. DO NOT buy your paint from TCP GLOBAL!
Absolutely the worst post sale customer service. The worst.
Re: Paint work on a Survivor? [Re: formula_s] #2504632
06/05/18 01:29 AM
06/05/18 01:29 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Backtape off the lower contour, blend up but not to it, polish back the blend. Color match will be critical and probably not easy. Pigments & chemicals are different now, but toners & metallic can be adjusted to get it right. It'll be time-consuming, and production-shop painters won't be interested, but there's the occasional painter who can appreciate the task and the challenge. A BC/CC can be applied to match the OEM texture, but they generally have more depth to the finish; might not be an issue on a lower quarter if you can't for some reason use a single-stage.
Re: Paint work on a Survivor? [Re: topside] #2504712
06/05/18 10:34 AM
06/05/18 10:34 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Y8 will be a challenge but not impossible to do with a single stage. Keep in mind the best job will still leave a ghost line in a metallic repair. The trick is to minimize it. The right amount of thinning and expanding work area in steps and blending agents can be successful.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Paint work on a Survivor? [Re: formula_s] #2504774
06/05/18 12:59 PM
06/05/18 12:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I ran across similar problem with my 76 Road Runner (orange - can't recall the right name) . . . most of the body shops around here wanted to repaint the whole panel, not just do a blend and such . . . gotta find someone old school (i.e. "experienced", vintage ?) that will take the time and has the knowledge . . . good luck !
Re: Paint work on a Survivor? [Re: formula_s] #2505161
06/06/18 12:04 PM
06/06/18 12:04 PM
New York
rarefish Offline
rarefish  Offline
New York
Boy, this question sure hits home. I dealing with pretty much the same issue on my survivor 1969 Dart that is B7 blue. The drivers 1/4 panel was replaced when the car was 3 months old due to an accident. It was painted with lacquer and that paint is now shot. I was counting on a local shop that was run by some old timers to repaint the 1/4, but I just found out that they have closed up and are retiring.
Re: Paint work on a Survivor? [Re: formula_s] #2505196
06/06/18 01:22 PM
06/06/18 01:22 PM
MO
cdp Offline
cdp  Offline
MO
Rarefish, you might try and contact the retirees anyway and see if they know someone else "old school" and reliable.
Re: Paint work on a Survivor? [Re: rarefish] #2505203
06/06/18 01:25 PM
06/06/18 01:25 PM
WV
Little Detroit Offline
WV
in most cases an offer of more money will delay retirement, remember cash is king.
Re: Paint work on a Survivor? [Re: Little Detroit] #2505208
06/06/18 01:40 PM
06/06/18 01:40 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I agree, and if its only a quarter panel plus blend they may be interested in it, the only problem is your warranty (if one) retires with them
Re: Paint work on a Survivor? [Re: formula_s] #2505247
06/06/18 02:50 PM
06/06/18 02:50 PM
Chicago
PurpleBeeper Offline
Chicago
These guys are all hitting home on this one. Many paints are no longer legal to buy/use (e.g. lead pigments or paints with tons of solvent).
Even if the paint "looks good" there has been "some" fading + every batch of paint (even back in 60's/70's) varied in color just a touch batch-to-batch.
Bottom line... it should be custom color matched. You can get test panels sprayed up (with an appropriate primer as close as possible to the original primer on the car) & blend several small batches to get the customer blend really, really close. Then, have someone who does custom paint work or an auto-restoration shop spray it, blending in the repair, as these guys have mentioned. That's the best you can do.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Paint work on a Survivor? [Re: formula_s] #2505301
06/06/18 04:46 PM
06/06/18 04:46 PM
NE Ohio
Govierjr. Offline
Govierjr.  Offline
NE Ohio
If possible locate the local paint supplier to the body shops in that area and see if they have access to camera that can analyze paint color on car and get a match that way.
the paint supplier's sales people should know who the painters in that area are that know what they are doing and willing to work in conjunction with you and the paint supplier to get the repair done.
I agree with the above keeping it small as possible. I assume repair area is below horizontal body line below marker lamp? Side stripes or no side stripes?
Re: Paint work on a Survivor? [Re: Govierjr.] #2506664
06/10/18 04:19 PM
06/10/18 04:19 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Any good shop should have the camera and their own mixing system.
Re: Paint work on a Survivor? [Re: AdamR] #2506830
06/10/18 11:27 PM
06/10/18 11:27 PM
North Pole,New York
North Pole,New York
Originally Posted By AdamR
[quote=Govierjr.]If possible locate the local paint supplier to the body shops in that area and see if they have access to camera that can analyze paint color on car and get a match that way.
Yes the area is right below the body line below the side marker light so that would be obvious area to break the new paint. Oddly , the paint scan matches to 2002 Lotus Mars Gold.
Re: Paint work on a Survivor? [Re: formula_s] #2506842
06/10/18 11:44 PM
06/10/18 11:44 PM
A collage of whims
A collage of whims
There are so many colors that it's possible to start with a close later color that can be tinted to get right. Also, any shop with a mixing bank should have different metallics to get the size right. Main thing is to find a painter who's motivated to get the tint, face (match when viewed straight on) & side cast (viewed at angles) right. That can be an issue on metallics. Some painters are good applicators but don't have an interest or ability to solve problems. Some don't appear to understand light, and some only like slam-bang production paychecks. Generally, a good paint jobber can give you an idea who the most talented painters are, because they should be dealing with their customers on at least a monthly basis.
