radator filter ??? #2503783
06/03/18 03:08 AM
06/03/18 03:08 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
has anyone heard of a filter that goes in the return line just before the radiator to filter the water someone told me he seen one I had my plug up
with some kind of white stuff do not know what it was but had to replace it 2004 1500 4.7 85000 miles
Re: radator filter ??? [Re: dragon] #2503805
06/03/18 08:47 AM
06/03/18 08:47 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Never heard of a radiator filter. work
Maybe they were thinking about the check valve in the trans cooler lines. shruggy I've heard they give problems stopping up.
Sounds like you had some kind of stop-leak in your radiator. Did you buy the truck used?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: radator filter ??? [Re: I_bleed_MOPAR] #2503860
06/03/18 12:20 PM
06/03/18 12:20 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I've seen an inline aluminum water filter that looks very similar to this inline thermostat but didn't find in a current google.
https://www.bing.com/th?id=OIP.HSvdnBYYR...o=5&pid=1.7
Also believe there was a discussion on Sweptline about an old style canister type that filtered inline of the heater hoses.
Re: radator filter ??? [Re: dragon] #2504529
06/04/18 09:51 PM
06/04/18 09:51 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Pretty sure semis use em.
Angry white pureblood male
Re: radator filter ??? [Re: dragon] #2504584
06/05/18 12:04 AM
06/05/18 12:04 AM
Central US
grancuda Offline
grancuda  Offline
Central US
I ran one on my '69 RoadRunner. The block had a lot of scaly rust & I had a new radiator I didn't want junk in. Worked good, just a little screen.
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: radator filter ??? [Re: dragon] #2504597
06/05/18 12:23 AM
06/05/18 12:23 AM
Central US
grancuda Offline
grancuda  Offline
Central US
It's called Trap from Golan Products.
2021 Toyota Supra
Re: radator filter ??? [Re: dragon] #2504781
06/05/18 01:15 PM
06/05/18 01:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: radator filter ??? [Re: John_Kunkel] #2508170
06/13/18 10:59 PM
06/13/18 10:59 PM
IN
ahy Offline
ahy  Offline
IN
If the block is well flushed and clean coolant is a filter needed?
A good basic block flush uses water (hose) and compressed air. Fill the block with water, turn on the air to blast it out and repeat as needed. The setup to do this can be purchased or made DIY.
Even better is pull the freeze plugs, use tools to loosen and remove crud in the water jackets, replace plugs and then flush.
Re: radator filter ??? [Re: dragon] #2575390
11/07/18 04:02 PM
11/07/18 04:02 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I have seen spin on filters, nothing new. Back in the 80's my Mack had a factory one. Also had coolant conditioner in it.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
