Pennzoil Synchromesh in 4-Speed ? #2503080
06/01/18 10:34 AM
06/01/18 10:34 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Does any one use Pennzoil Synchromesh in there 4-Speed Transmission ??
Thanks Tom C.
Re: Pennzoil Synchromesh in 4-Speed ? [Re: TOMRR] #2503105
06/01/18 11:28 AM
06/01/18 11:28 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
yep, been using it for 15 years, no known issues
Re: Pennzoil Synchromesh in 4-Speed ? [Re: TOMRR] #2503107
06/01/18 11:32 AM
06/01/18 11:32 AM
New York
rarefish Online content
rarefish  Online Content
New York
Is Pennzoil Synchromesh GL5 rated?
Re: Pennzoil Synchromesh in 4-Speed ? [Re: rarefish] #2503135
06/01/18 12:42 PM
06/01/18 12:42 PM
Kirkland, Washington
Pacnorthcuda Offline
No, and of course that's a good thing.
And think about it........"synchromesh" is the very reason (brass) that we don't want EP additives in our gearboxes.
Re: Pennzoil Synchromesh in 4-Speed ? [Re: TOMRR] #2503212
06/01/18 03:31 PM
06/01/18 03:31 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Correct you do NOT want a GL5 gear oil in your 833
Re: Pennzoil Synchromesh in 4-Speed ? [Re: TOMRR] #2503290
06/01/18 06:42 PM
06/01/18 06:42 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I tried it after reading about on this board awhile ago and it did not like it. Gear grinding du jour.
This subject has been debated many times here with many informative and interesting posts. It's a worthy topic with the search function.
My 2 cents...
Buy the juice Jamie Passon sells!
Ron
Common sense is a flower that does not grow in everybody's garden
Re: Pennzoil Synchromesh in 4-Speed ? [Re: Ron_M] #2503358
06/01/18 10:11 PM
06/01/18 10:11 PM
IN
ahy Offline
ahy  Offline
IN
Sycromesh is a good lube for syncro transmissions that like lighter lube. An 833 likes heavier lube above very cold temps like <10 F. GL4 gear lube is good if you can find it around 90 weight or higher. Redline MT90 is probably better. A synthetic with high temp characteristics of 90 weight and syncro friendly.
Re: Pennzoil Synchromesh in 4-Speed ? [Re: TOMRR] #2503550
06/02/18 12:17 PM
06/02/18 12:17 PM
New York
New York
I put in STA-LUBE 85W-90 GL4 in my 833, but I started to notice a problem with getting it into 2nd gear when cold. Things improve some once its warmed up. I have had people tell me to go with a ATF / Gear Oil mix, but what ratio 50/50, 25/75 should I try?
Re: Pennzoil Synchromesh in 4-Speed ? [Re: rarefish] #2503569
06/02/18 01:31 PM
06/02/18 01:31 PM
A lot of the new Mopar 4 speed cars came with straight ATF in them from the factory for cars sold in cold weather states, mostly east of the Rockies and north of the Mason Dixon line work
Mopar had NP update the synchro assemblies multiple times also, the early 1964 to 1967 NP833 first generation synchro mesh where horrible to shift when cold, below 60F shruggy
