Suspension Question #250277
03/10/09 11:35 PM
03/10/09 11:35 PM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
As I was putting the center link in between the pitman arm and the idler arm I noticed the center link was tilted up towards the ilder arm and not horizontal as I expected. Other pictures of B-body undercarriages show a slight tilt in this direction but not as severe as mine looks right now (see picture). I have not tightened the nuts in the picture and that is why it looks exagerated....however I suspect my new (spicer) idler arm might be wrong. Second picture shows how close the top of the tie rod is to the torsion bar (almost touching). Once I tighten these I expect the tie rod end to go down about 1/4 inch or so but it will go up slightly when I tighten the idler arm nut. Anyone experience this or have an idea on how close the tie rod is from the torsion bar on a stock car?
Re: Suspension Question [Re: LYNCHROAD69.5] #250278
03/10/09 11:36 PM
03/10/09 11:36 PM
Massachusetts
Massachusetts
Second pic
Re: Suspension Question [Re: LYNCHROAD69.5] #250279
03/11/09 04:54 PM
03/11/09 04:54 PM
Massachusetts
Massachusetts
Anybody.....
Re: Suspension Question [Re: LYNCHROAD69.5] #250280
03/11/09 05:21 PM
03/11/09 05:21 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Wayne.
There's definitely something going on there.. I believe it's your idler arm.. If no one posts a pic before I can break away from playing Mr. Mom, I'll take a pic of the original idler arm to my '68 in position on the k-member and see what it looks like....
Edit:
Here's a picture I just took... It's what was on the car when I got it and I have no reason to doubt it's not original...
Troy
Houston Mopar Connection Club
Re: Suspension Question [Re: LYNCHROAD69.5] #250281
03/12/09 10:00 AM
03/12/09 10:00 AM
Minn
SportF Offline
SportF  Offline
Minn
Is that link symmetrical? I think, maybe just the early cars, but it can be put on backwards. Is this perhaps the case?
Re: Suspension Question [Re: SportF] #250282
03/12/09 10:57 AM
03/12/09 10:57 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The angle of the idler arm looks incorrect to me. Note the angle in the 2 photos posted. Every center link I have, and can remember seeing on a car, has been horizontal.
