4 Spd Quick Question #2502607
05/31/18 10:44 AM
05/31/18 10:44 AM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
What is the best way to top off my 833 4 speed in my Challenger?
Should I fill only up to the fill plg?
I do no have a lift or anything and I want to make sure I have it filled enough. Thanks
Re: 4 Spd Quick Question [Re: 70VERT] #2502621
05/31/18 11:22 AM
05/31/18 11:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The problem is the lube is so damn thick !! Usually I fill the box before installing it. Good luck!!
Re: 4 Spd Quick Question [Re: 70VERT] #2502673
05/31/18 01:04 PM
05/31/18 01:04 PM
New York
rarefish Online content
rarefish  Online Content
New York
I went out and bought one of those plastic hand pumps that go into the gallon jug. It sure made life easier when putting gear oil into a rear end or a 4 speed box.
Re: 4 Spd Quick Question [Re: rarefish] #2502692
05/31/18 01:51 PM
05/31/18 01:51 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I fill mine just like an automatic. I keep a funnel with a length of garden hose on it for this, fill from under the hood with a pan under the trans. When I put in the proper amount I go under and pull the hose out of filler hole and any extra in the hose or trans. just drips out into pan. When dripping stops your done.
Ron
Re: 4 Spd Quick Question [Re: 70VERT] #2502736
05/31/18 03:37 PM
05/31/18 03:37 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
The way I fill my transfer case is to borrow a pointy cap from a gear oil bottle, put an appropriate sized rubber hose tightly over the tip, and holding the bottle horizontal, squeeze it in. You won't get every last bit out of the bottle, but you'll get it done.
Re: 4 Spd Quick Question [Re: rarefish] #2502739
05/31/18 03:38 PM
05/31/18 03:38 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
iagree
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 4 Spd Quick Question [Re: 70VERT] #2502779
05/31/18 05:39 PM
05/31/18 05:39 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Make sure you use a GL-4 rated fluid, NOT GL-5.
Re: 4 Spd Quick Question [Re: 70sixpkrt] #2502943
05/31/18 11:25 PM
05/31/18 11:25 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
thanks everybody. I think I have enough ideas to get it done
Re: 4 Spd Quick Question [Re: 70VERT] #2503085
06/01/18 10:50 AM
06/01/18 10:50 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Another vote for the small plastic hand pump on gallon jug.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
