Oil cooler kits #2501799
05/29/18 04:04 PM
05/29/18 04:04 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Looks like i will need an oil cooler for sure now. Two 20 minutes trips had the oil temp just under 260* when i rolled back in the garage. Who makes a good complete kit for under $300 with the fan.
Re: Oil cooler kits [Re: mopar dave] #2501910
05/29/18 06:56 PM
05/29/18 06:56 PM
AndyF Offline
AndyF  Offline
I'm not sure about a kit with a fan, never seen one of those. I do have a new Earl's cooler that I'm not using. I'll make you a good deal on it if you're interested.
Re: Oil cooler kits [Re: mopar dave] #2501912
05/29/18 07:07 PM
05/29/18 07:07 PM
NY usa
540challenger Offline
NY usa
B&m makes a real nice unit with the fan and a built in temp sender to control when the fan goes on plus it comes with the pigtails, u do need a relay however the price is not for the anyone with a weak heart.
https://www.summitracing.com/parts/bmm-70297
They have a smaller unit but price is still up there.
Re: Oil cooler kits [Re: mopar dave] #2501919
05/29/18 07:25 PM
05/29/18 07:25 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I'm curious and may sound like a true rookie but how do you plumb it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Oil cooler kits [Re: 67mprfan] #2501926
05/29/18 07:33 PM
05/29/18 07:33 PM
Mt Morris Michigan
Mt Morris Michigan
Theres an adaptor that mounts under the oil filter and have provisions for hose fittings.
Re: Oil cooler kits [Re: AndyF] #2501928
05/29/18 07:35 PM
05/29/18 07:35 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks Andy. I think you offered that before. Is that big enough? I really would prefer a kit form cooler.
Re: Oil cooler kits [Re: mopar dave] #2501938
05/29/18 08:17 PM
05/29/18 08:17 PM
Mt Morris Michigan
Mt Morris Michigan
Been googling oil temps. Looks like the circle track guys are seeing 260-310 oil temps with and without coolers. With 90*+ temps here last few days in might just be borderline for a oil cooler. 80-85 would normal here on a hot day. Gonna continue to look for a cooler kit without the fan.
Re: Oil cooler kits [Re: mopar dave] #2502005
05/29/18 10:59 PM
05/29/18 10:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
As usual, no one is listening.
Boffin Emeritus
Re: Oil cooler kits [Re: mopar dave] #2502030
05/29/18 11:52 PM
05/29/18 11:52 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Dave, mine is a pieced together cooler, I purchased a sandwich plate from ebay and did some serious porting to the inside for more flow, then fitted -12 male flares. 2x -12 braided lines and into a cooler like in Andy's pic.
Dont go too cheap on this, you need it to flow.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Oil cooler kits [Re: ozymaxwedge] #2502048
05/30/18 12:39 AM
05/30/18 12:39 AM
Mt Morris Michigan
Mt Morris Michigan
Been lookin at the G Plus kits on ebay and Derale, but the Derale kit does not come with braided hoses.
Re: Oil cooler kits [Re: mopar dave] #2502370
05/30/18 07:06 PM
05/30/18 07:06 PM
Mt Morris Michigan
Mt Morris Michigan
Just for comparison, anyone here using a oil temp gauge on a lo deck without any fill? Would be nice to see a normal temp number.
Re: Oil cooler kits [Re: mopar dave] #2502379
05/30/18 07:45 PM
05/30/18 07:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Dumb question probably, but why did you decide to run a filled block on a car you said would be 99% street driven?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Oil cooler kits [Re: B3422W5] #2502390
05/30/18 08:17 PM
05/30/18 08:17 PM
Mt Morris Michigan
Mt Morris Michigan
Well, not a dumb question at all. Because i wanted to run it hard and not break the #1 cylinder which soniced quite thin. I wanted to sleeve it,but shop suggested filling it. They filled damn near to the deck.
Re: Oil cooler kits [Re: mopar dave] #2502551
05/31/18 04:12 AM
05/31/18 04:12 AM
ca
brownout Offline
brownout  Offline
ca
https://proshop.summitracing.com///parts/bdd-1300611
Not a complete kit but a good cooler and fan for the money. -10 an male fittings. If you want to activate the fan off of oil temp you would just need a thermostat switch for your temp range and relay to power the fan.
Re: Oil cooler kits [Re: mopar dave] #2502570
05/31/18 08:23 AM
05/31/18 08:23 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I’ve been considering running and oil cooler on my 65
Never thought about a fan. Thanks for posting this.
I run a remote oil filter due to clearance issues.
I assume I can plumb the cooler into the remote filter lines - but should it be plumbed before or after the filter ?
I run -8 (1/2”) lines. Should they be larger ? M63HV pump, 1/2” pick up 7 qt pan
Re: Oil cooler kits [Re: NTOLERANCE] #2502604
05/31/18 10:41 AM
05/31/18 10:41 AM
Mt Morris Michigan
Mt Morris Michigan
I dont know whats really required for hose size, but im concerned about oil flow and dont want to destroy my new engine like the last one. Seems like -8 would be plenty.
Re: Oil cooler kits [Re: mopar dave] #2502610
05/31/18 10:56 AM
05/31/18 10:56 AM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
The highest fill on a B/RB should be just below the bottom hole on the water pump and parallel to the deck any higher than that the block becomes a real nice boat anchor!
Re: Oil cooler kits [Re: DoubleD] #2502614
05/31/18 11:04 AM
05/31/18 11:04 AM
Mt Morris Michigan
Mt Morris Michigan
I believe its 3" below the deck surface. not sure where that puts it to the water pump level. Highest fill i ever seen.
Re: Oil cooler kits [Re: mopar dave] #2502698
05/31/18 01:56 PM
05/31/18 01:56 PM
My old 518 C.I. 400 pump gas stroker motor, 4.375 bore, ran real close to the water temps(160 to 200 F) up here in the summer after driving 25 to 40 minutes shruggy
Low profile stock 6 quart Mopar 1970/71 hemi 6 pack oil pan with the stock 440 3/8 pick up up
Re: Oil cooler kits [Re: Cab_Burge] #2502715
05/31/18 02:32 PM
05/31/18 02:32 PM
Mt Morris Michigan
Mt Morris Michigan
I read some where 20-40* over coolant temp was normal. Yours ran really cool and shows i need a cooler especially on 90*+ days. Still looking for a complete kit but only finding cheap chinese kits or $700 kits.
