Re: Oil cooler kits
[Re: mopar dave]
#2501912
05/29/18 07:07 PM
05/29/18 07:07 PM
Posts: 2,826 NY usa
540challenger
NY usa
B&m makes a real nice unit with the fan and a built in temp sender to control when the fan goes on plus it comes with the pigtails, u do need a relay however the price is not for the anyone with a weak heart. https://www.summitracing.com/parts/bmm-70297They have a smaller unit but price is still up there.
Re: Oil cooler kits
[Re: mopar dave]
#2501919
05/29/18 07:25 PM
05/29/18 07:25 PM
Posts: 1,030 ohio
67mprfan
ohio
I'm curious and may sound like a true rookie but how do you plumb it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Oil cooler kits
[Re: mopar dave]
#2502030
05/29/18 11:52 PM
05/29/18 11:52 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Dave, mine is a pieced together cooler, I purchased a sandwich plate from ebay and did some serious porting to the inside for more flow, then fitted -12 male flares. 2x -12 braided lines and into a cooler like in Andy's pic. Dont go too cheap on this, you need it to flow.
1963 Plymouth Max Wedge 1971 Barracuda
Re: Oil cooler kits
[Re: mopar dave]
#2502379
05/30/18 07:45 PM
05/30/18 07:45 PM
Posts: 11,717 Portage,michigan
B3422W5
Portage,michigan
Dumb question probably, but why did you decide to run a filled block on a car you said would be 99% street driven?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Oil cooler kits
[Re: mopar dave]
#2502570
05/31/18 08:23 AM
05/31/18 08:23 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I’ve been considering running and oil cooler on my 65 Never thought about a fan. Thanks for posting this.
I run a remote oil filter due to clearance issues. I assume I can plumb the cooler into the remote filter lines - but should it be plumbed before or after the filter ?
I run -8 (1/2”) lines. Should they be larger ? M63HV pump, 1/2” pick up 7 qt pan
Re: Oil cooler kits
[Re: mopar dave]
#2502610
05/31/18 10:56 AM
05/31/18 10:56 AM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
Well, not a dumb question at all. Because i wanted to run it hard and not break the #1 cylinder which soniced quite thin. I wanted to sleeve it,but shop suggested filling it. They filled damn near to the deck. The highest fill on a B/RB should be just below the bottom hole on the water pump and parallel to the deck any higher than that the block becomes a real nice boat anchor!
Re: Oil cooler kits
[Re: mopar dave]
#2502698
05/31/18 01:56 PM
05/31/18 01:56 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Just for comparison, anyone here using a oil temp gauge on a lo deck without any fill? Would be nice to see a normal temp number. My old 518 C.I. 400 pump gas stroker motor, 4.375 bore, ran real close to the water temps(160 to 200 F) up here in the summer after driving 25 to 40 minutes Low profile stock 6 quart Mopar 1970/71 hemi 6 pack oil pan with the stock 440 3/8 pick up
