Re: Carter fuel pump rebuild
[Re: Gramps06]
#763444
08/03/10 09:37 PM
08/03/10 09:37 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Hello! Welcome to the site.. .... I came across this article a while back while checking on a carter fuel pump rebuild...It has some good pics and is easy to follow... link ...Makes for some good reading and might help answer a few questions...And will also give you a back to the top for some more replies for that exact model...
[Re: Gramps06]
#2501734
05/29/18 01:52 PM
05/29/18 01:52 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
I've been searching for the rebuild kit, but have not had any luck. Does anyone know the part# and vendor for the kit? M6903 carb
68 Charger 70 Cuda
[Re: FC7cuda]
#2501750
05/29/18 02:21 PM
05/29/18 02:21 PM
RapidRobert
Not for sure but I would try eBay & google it
[Re: lewtot184]
#2501861
05/29/18 05:22 PM
05/29/18 05:22 PM
FC7cuda
Dallas, Texas
unless the mancini rebuild kit has changed since I lost bought one by no means buy it. it's garbage. Thanks for the "heads up"
68 Charger 70 Cuda
[Re: tman]
#2501863
05/29/18 05:22 PM
05/29/18 05:22 PM
FC7cuda
Dallas, Texas
Is your pump like this?
https://www.jegs.com/i/Carter/180/M6903/10002/-1?CAWELAID=230006180037506944&CAGPSPN=pla&CAAGID=15769068431&CATCI=aud-224375369591:pla-208650390311&CATARGETID=230006180037475715&cadevice=c&gclid=Cj0KCQjw9LPYBRDSARIsAHL7J5kElxR8RBf3UhphtxIBIW5gKCTWYkEcve6XgrSHge61IJZKTAHYmw0aAimoEALw_wcB Yes.
68 Charger 70 Cuda
