Carter fuel pump rebuild #763443
08/02/10 01:34 PM
08/02/10 01:34 PM
Denver, Colorado
Gramps06 Offline OP
Gramps06  Offline OP
Denver, Colorado
New to this site, so please forgive my ignorance if any...
When rebuilding a Carter mechanical fuel pump (M6902/M6903), is there a special tool required to remove/install the check valves? Or does one simply use needle nose pliers/vise-grips? Special end spanner wrench? Also, when installing the new diapgragm (assembly), how are the shaft end caps (rivets?) installed and/or crimped?
Re: Carter fuel pump rebuild [Re: Gramps06] #763444
08/03/10 09:37 PM
08/03/10 09:37 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hello! Welcome to the site.. .... I came across this article a while back while checking on a carter fuel pump rebuild...It has some good pics and is easy to follow... link ...Makes for some good reading and might help answer a few questions...And will also give you a back to the top for some more replies for that exact model...
Re: Carter fuel pump rebuild [Re: screamindriver] #763445
08/04/10 10:39 AM
08/04/10 10:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why waste the time? just go buy a new one. they are pretty cheap.
Coming soon!!!!
Re: Carter fuel pump rebuild [Re: Mr.Yuck] #763446
08/06/10 11:27 PM
08/06/10 11:27 PM
Denver, Colorado
Gramps06 Offline OP
Gramps06  Offline OP
Denver, Colorado
Thank you for your opinion. Normally I would do just what you sugested, buy a new one, however, in this case, the one I have that I need to rebuild is not built anymore, nor does anyone even list an equal replacement. It is for a marine application and I am having to re-use the housings due to fule-in and fuel out port locations.
Re: Carter fuel pump rebuild [Re: screamindriver] #763447
08/06/10 11:33 PM
08/06/10 11:33 PM
Denver, Colorado
Gramps06 Offline OP
Gramps06  Offline OP
Denver, Colorado
Thank you for the link. The directions explain that the valves are driven in for a press-fit. I thought they were threaded. I have an old Carter that is for a marine application that is no longer made, nor is there any recomended replacement. I'm having to re-use the housings due to fuel-in and fuel-out port locations. Your link answered the question. thank you again.
Re: Carter fuel pump rebuild [Re: Gramps06] #2501734
05/29/18 01:52 PM
05/29/18 01:52 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
I've been searching for the rebuild kit, but have not had any luck. Does anyone know the part# and vendor for the kit? M6903 carb
68 Charger
70 Cuda
Re: Carter fuel pump rebuild [Re: FC7cuda] #2501750
05/29/18 02:21 PM
05/29/18 02:21 PM
Not for sure but I would try eBay & google it
Re: Carter fuel pump rebuild [Re: Gramps06] #2501752
05/29/18 02:28 PM
05/29/18 02:28 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Yeah, found this one which is close to the cost of a new pump, hoping to find a more reasonable cost for the kit or just diagrams.
http://www.manciniracing.com/bherekit.html
68 Charger
70 Cuda
Re: Carter fuel pump rebuild [Re: Gramps06] #2501784
05/29/18 03:36 PM
05/29/18 03:36 PM
WA
tman Offline
tman  Offline
WA
Is your pump like this?
https://www.jegs.com/i/Carter/180/M6903/10002/-1?CAWELAID=230006180037506944&CAGPSPN=pla&CAAGID=15769068431&CATCI=aud-224375369591:pla-208650390311&CATARGETID=230006180037475715&cadevice=c&gclid=Cj0KCQjw9LPYBRDSARIsAHL7J5kElxR8RBf3UhphtxIBIW5gKCTWYkEcve6XgrSHge61IJZKTAHYmw0aAimoEALw_wcB
Re: Carter fuel pump rebuild [Re: Gramps06] #2501810
05/29/18 04:25 PM
05/29/18 04:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
unless the mancini rebuild kit has changed since I lost bought one by no means buy it. it's garbage.
Re: Carter fuel pump rebuild [Re: Gramps06] #2501811
05/29/18 04:25 PM
05/29/18 04:25 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Yes.
68 Charger
70 Cuda
Re: Carter fuel pump rebuild [Re: Gramps06] #2501852
05/29/18 05:07 PM
05/29/18 05:07 PM
VA
dragon slayer Offline
VA
Small punch and the check valves come out nicely. Look at how far they are inserted in the housing before removal. Use small socket to press or tap back in. Kits come with new gasket seal, springs and a brake type rivet in place of the older head. You can reuse head as long as fit is tight.
Re: Carter fuel pump rebuild [Re: lewtot184] #2501861
05/29/18 05:22 PM
05/29/18 05:22 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Thanks for the "heads up"
68 Charger
70 Cuda
Re: Carter fuel pump rebuild [Re: tman] #2501863
05/29/18 05:22 PM
05/29/18 05:22 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Yes.
68 Charger
70 Cuda
