Trying to locate origin of a caliper #2501823
05/29/18 04:41 PM
05/29/18 04:41 PM
Western NY
Smalls Offline OP
Smalls  Offline OP
Western NY
Hi all. I have a Frankenstein Truck. It's a 1954 Ford Body, Chevy 350 motor and a MOPAR front end. In trying to replace the brake system I have discovered that the pads are from a 1974 Roadrunner, the rotors are from a 1975 Coronet, I am coming up empty on the origin of the caliper. The numbers on the caliper include 4126, 508, 807 and G445A or perhaps 6445A it's rather worn. Single piston. I cannot figure out how to link a picture to this post. Everything we have tried to match up to date will not work. Any advice/insight is appreciated. Thanks!
Re: Trying to locate origin of a caliper [Re: Smalls] #2501872
05/29/18 05:31 PM
05/29/18 05:31 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Most front ends that are grafted onto trucks are Aspen/Volare. I have seen it done a dozen times. work
JB Rhinehart, Realist
A-Body's RULE!
Re: Trying to locate origin of a caliper [Re: Rhinodart] #2501882
05/29/18 05:44 PM
05/29/18 05:44 PM
dogdays Offline
dogdays  Offline
There is only one easily swapped Mopar front end...I bet good money it has transverse torsion bars, so it's the Aspen/Volare/basically everything else after that, front end. It's a generic piece. Chrysler was going under and couldn't afford to change many things up.
Do a little searching in the online lending library, IE, Rockauto.com.
There are only two types of calipers for that front end: the pin type and the slider type. They were used over numerous years and models. Your pads will cross reference with one of the two types.
If I'm incorrect someone will be certain to point it out.
R.
Re: Trying to locate origin of a caliper [Re: Smalls] #2502008
05/29/18 11:07 PM
05/29/18 11:07 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
You're killing me Smalls!
I agree with the others that it's likely to be what we commonly call an FMJ cradle swap.
Look up calipers for a 76-80 Violate and see if they're close.
Angry white pureblood male
