Lamp Out Warning 2004 Ram 2500 #2501455
05/28/18 08:59 PM
05/28/18 08:59 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
I keep getting a lamp out warning light and buzzer on my 2004 Ram 2500
I have checked all the lights, all good. How do I disconnect this darn thing.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Lamp Out Warning 2004 Ram 2500 [Re: VCODE] #2501505
05/28/18 10:47 PM
05/28/18 10:47 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Could be corrosion on circuit board on taillights or the light sockets.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Lamp Out Warning 2004 Ram 2500 [Re: VCODE] #2501514
05/28/18 11:07 PM
05/28/18 11:07 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The bulb can fail intermittently. My 2007 Ram had a faulty taillight bulb that seemed to fail when slowing and making a right turn. Strange...I could signal right at a steady speed and there would be no chime. Maybe though....maybe it was the brake and turn at the same time that overwhelmed a marginal filament?
Re: Lamp Out Warning 2004 Ram 2500 [Re: Kern Dog] #2501667
05/29/18 11:44 AM
05/29/18 11:44 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Check the sockets for "blackening" around a bulb. This indicates a loose connection in the socket. If this is the case, you can take a small pick and gently pull the contacts out for better contact with the bulb. Badly burnt may require replacement.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Lamp Out Warning 2004 Ram 2500 [Re: I_bleed_MOPAR] #2501820
05/29/18 04:39 PM
05/29/18 04:39 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks for all the replies. I will check all sockets
Thanks Bob
Re: Lamp Out Warning 2004 Ram 2500 [Re: VCODE] #2501935
05/29/18 08:15 PM
05/29/18 08:15 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Same thing happened to my 04 Cummins Ram. Turned out to be the TIPM... mad
JB Rhinehart, Realist
A-Body's RULE!
Re: Lamp Out Warning 2004 Ram 2500 [Re: VCODE] #2501948
05/29/18 08:54 PM
05/29/18 08:54 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i had 2 of those trucks and both did that. I found the bulbs from Napa that are all glass held up the best and stopped it for the most part. The parts store Sylvania or whatever with the plastic base kept melting and would lose contact.
