Page 1 of 3 1 2 3
Sneak peek pecker extension #2501197
05/28/18 12:58 AM
05/28/18 12:58 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I will do some back-to-back to see what it is worth..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Sneak peek pecker extension [Re: WHITEDART] #2501218
05/28/18 02:23 AM
05/28/18 02:23 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pro mod stuff. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Sneak peek pecker extension [Re: pittsburghracer] #2501240
05/28/18 08:49 AM
05/28/18 08:49 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
what is it supposed to do?
Re: Sneak peek pecker extension [Re: bonefish] #2501244
05/28/18 09:24 AM
05/28/18 09:24 AM
Locomotion Offline
Locomotion  Offline
Trips the finish line beams instead of the tires. It should be high enough (3" according to rules) above the ground so it doesn't affect the starting line beams. But it will quicken ET's and may make it more difficult for other racers to judge the car at the finish line.
Some classes don't allow that mod, but cars with certain front end configurations and/or soft front suspensions can be made to trip the lights with their factory spoilers, especially if you brake at just the right time.
Look around at the races next time. You might be surprised. Used on dragsters and roadsters too.
Re: Sneak peek pecker extension [Re: Locomotion] #2501265
05/28/18 11:02 AM
05/28/18 11:02 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Re: Sneak peek pecker extension [Re: WHITEDART] #2501277
05/28/18 11:45 AM
05/28/18 11:45 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Could be a game changer.... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Sneak peek pecker extension [Re: racerhog] #2501280
05/28/18 11:56 AM
05/28/18 11:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They have a max length also.. if I remember
right it was 36" from the center of spindle
to the front edge.. they do help.. you shorten
the track by X length
wave
Re: Sneak peek pecker extension [Re: MR_P_BODY] #2501283
05/28/18 12:02 PM
05/28/18 12:02 PM
PA.
"Little"John
"Little"John
PA.
Ive heard that if you sand blast all the paint off the car and remove the license plate it will run faster too.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sneak peek pecker extension [Re: pittsburghracer] #2501285
05/28/18 12:15 PM
05/28/18 12:15 PM
bean town ....Ca
W
W
bean town ....Ca
every little detail matters when you are running naturally aspirated.. in 1/8 mile racing a lot of races are won and lost within 3 feet.. we struggle for every bit of et that we find at this point.. and you can count on the next time the car gets painted it will be completely stripped to bare metal..
Re: Sneak peek pecker extension [Re: WHITEDART] #2501288
05/28/18 12:34 PM
05/28/18 12:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A painted surface is slipperier than a non painted
surface... BUT paint adds weight.. why do the
hot shot NHRA & NASCAR run painted surfaces.. they
also need a place to advertise but the weight of
the paint is also added into the total weight.. if
I recall correctly a paint job on a car my size
was 50#.. a full size can be as high as 100#
EDIT
Dollar VS dollar it is was more expensive to just
do a bare paint job.. if your talking no body
filler.. but even if you do a bare metal your
still gonna have to spray a clear to protect the
metal so its not truly a paintless job
wave
Re: Sneak peek pecker extension [Re: MR_P_BODY] #2501306
05/28/18 01:21 PM
05/28/18 01:21 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
on a tour though the Boeing factory we where told one 747 they put 600 gallon of paint on the airplane,thats around 4000 lbs.when its being
painted the wheels are on scales!
Re: Sneak peek pecker extension [Re: dodger mope] #2501310
05/28/18 01:29 PM
05/28/18 01:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds about right to me
wave
Re: Sneak peek pecker extension [Re: dodger mope] #2501318
05/28/18 01:47 PM
05/28/18 01:47 PM
John Dieana said something to me about paint weight on race cars years ago, I would like to see the before and after weight of a car without paint and then with paint due to the evaporation of all the liquids n the paint work confused
BTW, we call them stripe takers out here, not pecker extensions whistling shruggy
Re: Sneak peek pecker extension [Re: Cab_Burge] #2501319
05/28/18 02:00 PM
05/28/18 02:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the evap will vary just the way a guy sprays.. I
forgot the numbers on my car.. I have painted it
6 different times but sanded back to metal each
time and if I recall right it only varied like
6#.. that was a base/clear with a sealer each time
wave
Re: Sneak peek pecker extension [Re: WHITEDART] #2501343
05/28/18 03:44 PM
05/28/18 03:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Pecker extensions,- I was thinking something else..
Re: Sneak peek pecker extension [Re: WHITEDART] #2501349
05/28/18 03:58 PM
05/28/18 03:58 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
So, basically, you are shortening the distance to trip the beams. Might make for a quicker et slip, but in reality, it isn't any faster. I'm building N/A because I need to prove to myself how good I am. I don't need any sort of drag race version of Viagra to help me.
[image][/image]
Re: Sneak peek pecker extension [Re: cudaman1969] #2501357
05/28/18 04:08 PM
05/28/18 04:08 PM
my own world
theraif Online tonguue
theraif  Online Tonguue
my own world
skip to 1:54
Re: Sneak peek pecker extension [Re: WHITEDART] #2501389
05/28/18 05:58 PM
05/28/18 05:58 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It helps level the playing field with the new cars that are low and have long noses.
68 Barracuda Formula S 340
Re: Sneak peek pecker extension [Re: sgcuda] #2501391
05/28/18 06:09 PM
05/28/18 06:09 PM
bean town ....Ca
W
W
bean town ....Ca
obviously you have outsmarted yourself.this is not for looks nor is it cheating.. it's about winning races.. we race against Ferd's and shitolets that have a long frontal area.. as smart as you are do you think my Dodge Dart should be the first one to the finish line but lose the race.. because the front valence of the Mustang got to the beam before my tire.. fan
Re: Sneak peek pecker extension [Re: WHITEDART] #2501519
05/28/18 11:23 PM
05/28/18 11:23 PM
racerhog Offline
racerhog  Offline
LOL,
It's all about changing the game and turning on the win light.....
Grab a lane boys and girls... Or Just sit and watch how it's done...
Bob(Cowboy)Hogan
Monrovia So-Cal
Page 1 of 3 1 2 3
