Need help with overheating issues on 2006 PT Cruiser. #2500740
05/26/18 06:42 PM
05/26/18 06:42 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
My daughter has a 2006 PT Cruiser that is having a overheating issue. Hoping you guys can provide some troubleshooting guidance.
After driving for approximately 30 minutes it will overheat. When it overheats, the car will shut off completely with no warning. After a couple of hours it cools down enough to start and add water. It usually loses over a gallon of water. There is no evidence of antifreeze leaking or on the ground. Currently it just has water in it as she's been adding water to drive it. She had it pressure tested today at a garage and they said it was fine. Fans checked out ok. There is no evidence of antifreeze in the oil.
Suggestions on troubleshooting it?
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Need help with overheating issues on 2006 PT Cruiser. [Re: Dixie] #2500747
05/26/18 07:10 PM
05/26/18 07:10 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If it's losing coolant but not on the ground the only other choice is a head gasket leak and its going out the exhaust....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Need help with overheating issues on 2006 PT Cruiser. [Re: HemiRick] #2500757
05/26/18 07:40 PM
05/26/18 07:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yep,
Did one for this exact issue last year.
ROYAL PIA job by the way
Look REALY close on the pass side of the engine towards the front of the car, just below the area where the thermostat hsg is located.
Re: Need help with overheating issues on 2006 PT Cruiser. [Re: Dixie] #2500767
05/26/18 08:12 PM
05/26/18 08:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That might not show up on a cold engine pressure test.
Re: Need help with overheating issues on 2006 PT Cruiser. [Re: Dixie] #2500888
05/27/18 02:10 AM
05/27/18 02:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Change the thermostat.. simple things first
and a lot easier
wave
Re: Need help with overheating issues on 2006 PT Cruiser. [Re: Dixie] #2500971
05/27/18 12:15 PM
05/27/18 12:15 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
First, check for combustion gases in the coolant which will tell you if you have a head gasket problem. There are a number of ways to do that. Do an internet search for your options.
Second, the fan has two speeds and it is very common for the low speed to go out. I have changed a bunch of them. In fact, it is common enough, that it would be a good idea to go ahead and change it.
And it is the fan motor itself that fails and only on the low speed. Not the relays. So, the fan assembly must be replaced.
It is possible now that the PT will have both problems. The fan problem leads to overhead problems, which kills the head gasket. As with many iron block, aluminum head engines, the PT's 2.4 is not tolerant of overheating.
Master, again and still
Re: Need help with overheating issues on 2006 PT Cruiser. [Re: Dixie] #2500993
05/27/18 01:44 PM
05/27/18 01:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
IF, it going out the tail pipe, you need to fix it now. I had the same thing on my Neon, kept losing water, and I could even hear it gurgling back into the overflow bottle, and could smell anti freeze coming out the exhaust pipe. What was going on was the gasket working towards braking, then all of a sudden, all of the water will go out the tail pipe, and leave her sitting when the gasket lets go.
