Re: Mods to fit Performer rpm intake with flat valley pan RB
[Re: Pockets]
#2500989
05/27/18 01:21 PM
05/27/18 01:21 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Yes you can mill it.
The pan cracking is a sign of another problem in you motor.
[Re: Pockets]
#2501043
05/27/18 05:04 PM
05/27/18 05:04 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
The only time I had a valley pan split was when a exhaust lobe ground off causing extreme pressure buildup in the crank case. It bulged up and split down the center. Pulled the engine apart ,found the problem , changed out the cam/lifters and all was good. Never had it happen on any other engine.
[Re: Pockets]
#2501109
05/27/18 09:22 PM
05/27/18 09:22 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
With no heat crossover in the heads you can just remove it. I use an Indy valley cover with a Performer RPM and I just cut it off with a cut-off wheel. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Pockets]
#2502102
05/30/18 03:11 AM
05/30/18 03:11 AM
Posts: 27 AB
Pockets
AB
