Alternator to cylinder head: How close is too close? #2500167
05/25/18 12:41 AM
05/25/18 12:41 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
I'm adding a Sanden a/c compressor to my 440, so I'm currently mocking it up. In order to get the alternator pulley to line up with the (Bouchillon #4013) crank pulley, my alternator needs to move toward the rear, maybe 3/8" to 1/2" from where it currently is. If I do this, it will be approximate 1/8" to 3/16" from the right cylinder head. Is this too close? I'm concerned about heat damaging the alternator. Do I need to worry? Thanks for any opinions or suggestions.
Roger
Re: Alternator to cylinder head: How close is too close? [Re: Fab64] #2500200
05/25/18 07:23 AM
05/25/18 07:23 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Heat won't be the problem. Adjustability and clearance for the terminals will be.
Angry white pureblood male
Re: Alternator to cylinder head: How close is too close? [Re: Fab64] #2500209
05/25/18 08:05 AM
05/25/18 08:05 AM
BDW Offline
BDW  Offline
That wouldn't worry me
Re: Alternator to cylinder head: How close is too close? [Re: Fab64] #2500315
05/25/18 02:38 PM
05/25/18 02:38 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Not a problem, the head only gets to 200 degrees or so.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Alternator to cylinder head: How close is too close? [Re: ruderunner] #2500324
05/25/18 03:17 PM
05/25/18 03:17 PM
IL
furious70 Offline
furious70  Offline
IL
+1 just make sure the batt lug can't come in contact with the block if the bracket flexes under load.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Alternator to cylinder head: How close is too close? [Re: furious70] #2500497
05/25/18 11:05 PM
05/25/18 11:05 PM
& if you do ever have to space an alt forward, crank/wp shims are commonly available
Re: Alternator to cylinder head: How close is too close? [Re: RapidRobert] #2500542
05/26/18 02:33 AM
05/26/18 02:33 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks, I was actually wondering about that today. up
Re: Alternator to cylinder head: How close is too close? [Re: Fab64] #2500551
05/26/18 02:58 AM
05/26/18 02:58 AM
440source has nice ones for the crank (probably for the pump too) & I have used chebby ones for the pump & not sure if I had to elongate the holes or not (no iirc) & I'm sure WP pulleys for us are out there & I've even used washers tho full support is way better. finding the correct depth pulleys for alignment is a real challenge (& the ratio does come into play).
Re: Alternator to cylinder head: How close is too close? [Re: Fab64] #2500590
05/26/18 09:34 AM
05/26/18 09:34 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
i'd run that clearance.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
