A904 Transmission Pan #2498669
05/21/18 03:50 PM
05/21/18 03:50 PM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
I'm looking for a replacement pan for my 904. The car is just a driver so I don't need anything crazy, just a stock stamped steel replacement. The current pan leaks because it's probably warped from 40 years of being taken on and off a number of times.
I know there are other Mopar transmissions that used the same pan, so maybe something is still available through a dealer?
No longer taking $h!t from anyone!
Re: A904 Transmission Pan [Re: DUFFMAN] #2498741
05/21/18 07:22 PM
05/21/18 07:22 PM
scratchnfotraction Offline
dealer has a replacement for newer trans that is a little deeper
a500 is 904 based
a518 is 727 based
IIRC runs about 60$ at the dealer
grab one of the newer style pan gaskets also.
they are no leak and reusable multiple times.
Re: A904 Transmission Pan [Re: DUFFMAN] #2498776
05/21/18 09:00 PM
05/21/18 09:00 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Be sure the pan gasket is the source of the leak, leaks from above often run down to the pan gasket before dripping off. The shift shaft seal and dipstick tube are often the leak source.
If it is the gasket, try the new style mentioned above...it seals bent pans better.
Re: A904 Transmission Pan [Re: DUFFMAN] #2498856
05/21/18 11:46 PM
05/21/18 11:46 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I'll look at it again, but it appears to be wet around the gasket. However, while the pan is off it would be a good time to replace the other 2 seals.
Re: A904 Transmission Pan [Re: DUFFMAN] #2498934
05/22/18 08:39 AM
05/22/18 08:39 AM
crlush Offline
crlush  Offline
I had the dipstick tube leak and thought it was pan gasket.
Re: A904 Transmission Pan [Re: DUFFMAN] #2498966
05/22/18 10:18 AM
05/22/18 10:18 AM
BDW Online content
BDW  Online Content
Changed my pan and gasket 4 times before figuring out it was the pivot pin leaking
Re: A904 Transmission Pan [Re: BDW] #2499335
05/23/18 02:34 AM
05/23/18 02:34 AM
STL
cdstl Offline
cdstl  Offline
STL
Get one of these and never look back. You can get them at the dealer but they cost more. The dealer claims that you need longer bolts, since the gasket is thicker, but I have one on my car and used the standard bolts.
Trans Pan Gasket
They don't leak and are reusable with no gasket material required. $35 seems like a lot for a gasket but it's money in the bank.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: A904 Transmission Pan [Re: cdstl] #2499381
05/23/18 10:16 AM
05/23/18 10:16 AM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
Trans Pan Gasket
Looks like a 727 gasket to me.
Re: A904 Transmission Pan [Re: DUFFMAN] #2499393
05/23/18 11:06 AM
05/23/18 11:06 AM
STL
cdstl Offline
cdstl  Offline
STL
Ooof, it is. I had been reading this post before but I forgot that it was a post about a 904.
Sorry
