1958 Dodge Regent
#2498310
05/20/18 05:36 PM
05/20/18 05:36 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
A good friend of mine selling a 58 Dodge Regent.... we made a deal and now I have another project on my hands soon I guess... lol Canadian car, it's a Dodge front end and Plymouth dash and rear. The bodywork was all done and painted but it has blisters so needs to be stripped. He's got all the trim, bumpers etc and the seats are all there and the upholstery is even good. Has good door panels with a little bit of warping on back panels Floors are rotten and need to be replaced but he already did inner and outer sills and left a ledge to attach to.... Glass is all good. No engine and trans. Hmmmmmm
CrAzYMoPaRGuY
Re: 1958 Dodge Regent
[Re: CrAzYMoPaRGuY]
#2498328
05/20/18 06:26 PM
05/20/18 06:26 PM
CrAzYMoPaRGuY
Canada
It was a flathead 6 car..... no flathead going back in though.... Not sure if I should swap spindles and try to adapt 70's van mounts on the frame and install a 360 I have..... or Dakota frame splice or or or....?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2498447
05/20/18 11:50 PM
05/20/18 11:50 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: CrAzYMoPaRGuY]
#2498461
05/21/18 12:31 AM
05/21/18 12:31 AM
Posts: 10,618 Freeport IL USA
poorboy
Freeport IL USA
My son is dealing with an original frame and suspension on a 57 Dodge wagon. If power steering is, or will be in play, do a Dakota clip. The original power steering is an unusual system that only fits a few years, and has little road feel. If you car has manual steering and you want to add power, you will have to deal with the original setup.
This day and age, finding a good Dakota donor that can still be converted to 5 bolt wheels (88-96) is getting tough, and depending on your motor choice, you really have to watch the motor height for hood clearance.
Fortunately, there is a lot of documentation right here concerning these cars. Read up, it can get pretty complex. Gene
[Re: moparpollack]
#2498515
05/21/18 04:26 AM
05/21/18 04:26 AM
CrAzYMoPaRGuY
Canada
Ha! I actually love that answer!! Every Thursday after work, floors almost finished.....
CrAzYMoPaRGuY
[Re: poorboy]
#2498516
05/21/18 04:29 AM
05/21/18 04:29 AM
CrAzYMoPaRGuY
Canada
Fortunately, there is a lot of documentation right here concerning these cars. Read up, it can get pretty complex. Gene Strangely I've been collecting Dakotas..... lol I have a few sets of brand new front 5 lug rotor/hubs too..... Thanks Gene!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2498549
05/21/18 10:21 AM
05/21/18 10:21 AM
Posts: 1,513 AZ
Mike P
AZ
Neat project, (love the color). If interested I do have a spare pair of original V8 57-58 Dodge and Plymouth frame mounts. The round motor mounts the V8 cars used are still available, but the “cans” that go on the motor can be hard to find and are different than between the Poly/Hemi motors and the B/RB engines. SANYO DIGITAL CAMERA by M Patterson, on Flickr If using the original frame/suspension, you will need a 57-58 center sump pan and pickup is you use a Poly/first gen Hemi. If you go B/RB and can’t find an early passenger car pan, a later B/RB pan will work if going the Big Block route, but it may need to be notched to clear the front crossmember. I’ve done front disc brake conversions a couple of different ways on the 57-58s. 70’s A body Disc brakes were a popular swap 15 years ago (before their were kits using the original spindles). The spindles bolt on, but the tie rods and sleeves need to be shortened and the steering stop modified. I have also used late 70s C body brakes but that is even more work and requires modification to the spindles. I’m using an old AAJ disc brake conversion on my 57 Plymouth’s original spindles and am happy with it. I not sure if AAJ is still in business, but I think Scare Bird has a similar kit. “…….If power steering is, or will be in play, do a Dakota clip……” I absolutely agree with poorboy. If I was just starting to build my 57 Plymouth (or the old 440 powered 57 Coronet I used to have) now it would definitely be getting a later modle front frame clip. The original steering boxes, both manual and especially power boxes suck on these cars. The way the box mounts and oil pan/torsion bar clearance issues make adapting something else (rack and pinion/modern steering box) very difficult is not impossible. I’m currently trying to adapt a 605 Saginaw box into my 57 Plymouth and if it is even possible, it’s going to be a lot of work. In addition to the steering box issues, a couple of other shortcomings include: The upper control arms are a 57-58 only item. They use very small control arm bushings that don’t like heavy engines (first gen Hemis or B/RB motor). Usually the bushings only last about 40-50K miles and are not pleasant to replace. They are also currently getting a little harder to find…..cost can run anywhere between $20 to$50 each (and you need 4). The drag link is also a wear item due to having joints on the outer ends. You can still find these rebuilt, but they are not real cheap.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: poorboy]
#2498714
05/21/18 06:26 PM
05/21/18 06:26 PM
Posts: 238 British Columbia, Canada
Old Ray
you really have to watch the motor height for hood clearance. Gene is bang on about this, it sits high. I did the Dakota subframe swap last week and reinstalled the stock Dakota engine this weekend. Because the engine sits at the Dakota height (coil springs held with threaded rod) and where you have set the ride height of the original frame determines how much hood clearance. Looked scary so garbed the tape measure, should be just OK, but this is for a ‘56 and I think the ‘57 and up have lower hood clearance. It was wishful thinking on my part, partly caused by something I read on the net, that the original Dakota engine location would work, NOT SO, needs to be 6 inches further back. Engine back out and mount relocating plates under construction today ,
[Re: Mike P]
#2498773
05/21/18 08:51 PM
05/21/18 08:51 PM
CrAzYMoPaRGuY
Canada
Neat project, (love the color). If interested I do have a spare pair of original V8 57-58 Dodge and Plymouth frame mounts. The round motor mounts the V8 cars used are still available, but the “cans” that go on the motor can be hard to find and are different than between the Poly/Hemi motors and the B/RB engines. SANYO DIGITAL CAMERA by M Patterson, on Flickr If using the original frame/suspension, you will need a 57-58 center sump pan and pickup is you use a Poly/first gen Hemi. If you go B/RB and can’t find an early passenger car pan, a later B/RB pan will work if going the Big Block route, but it may need to be notched to clear the front crossmember. I’ve done front disc brake conversions a couple of different ways on the 57-58s. 70’s A body Disc brakes were a popular swap 15 years ago (before their were kits using the original spindles). The spindles bolt on, but the tie rods and sleeves need to be shortened and the steering stop modified. I have also used late 70s C body brakes but that is even more work and requires modification to the spindles. I’m using an old AAJ disc brake conversion on my 57 Plymouth’s original spindles and am happy with it. I not sure if AAJ is still in business, but I think Scare Bird has a similar kit. “…….If power steering is, or will be in play, do a Dakota clip……” I absolutely agree with poorboy. If I was just starting to build my 57 Plymouth (or the old 440 powered 57 Coronet I used to have) now it would definitely be getting a later modle front frame clip. The original steering boxes, both manual and especially power boxes suck on these cars. The way the box mounts and oil pan/torsion bar clearance issues make adapting something else (rack and pinion/modern steering box) very difficult is not impossible. I’m currently trying to adapt a 605 Saginaw box into my 57 Plymouth and if it is even possible, it’s going to be a lot of work. In addition to the steering box issues, a couple of other shortcomings include: The upper control arms are a 57-58 only item. They use very small control arm bushings that don’t like heavy engines (first gen Hemis or B/RB motor). Usually the bushings only last about 40-50K miles and are not pleasant to replace. They are also currently getting a little harder to find…..cost can run anywhere between $20 to$50 each (and you need 4). The drag link is also a wear item due to having joints on the outer ends. You can still find these rebuilt, but they are not real cheap. Not sure which way it will go yet.... if at all lol I thin the original style might worry me because my blandest small block is a healthy hydraulic roller 360. I would probably go up from there as far as power goes and not sure I trust the original style mounts? Pans and engine location doesn't bother me. I might upgrade to a Dakota or FMJ clip but not sure yet.... I'll look at the car closely before I even think about it.
CrAzYMoPaRGuY
[Re: poorboy]
#2498882
05/22/18 12:56 AM
05/22/18 12:56 AM
Old Ray
Old Ray,When I moved the motor & trans back on the Dakota frame in my coupe, I bolted in a 1/4" thick plate to the frame (on each side) where the original motor mount bracket bolted to, and then drilled holes and bolted the motor mount brackets to the 1/4" plate. Well then I must be doing the right thing because that is exactly what I am doing. Mostly by accident, the only plate I had that was big enough was some 1/4 inch. I did the pass side this morning, drivers side tomorrow, did you gusset or put any extra reinforcement on, especially on the drivers side? There is one extra threaded hole on the drivers side that I will use as well. Thanks for the advice, much appreciated.
[Re: poorboy]
#2498921
05/22/18 04:32 AM
05/22/18 04:32 AM
CrAzYMoPaRGuY
Canada
I think an FMJ clip would be and absolute nightmare on one of these cars. The track width would be petty wide, and you would have to cut everything ahead of the firewall off. At that point, you might as well do a Dakota clip and get a more modern suspension.
Gene I went to look at a 1958 Plymouth for sale. It had a Fifth Ave clip. Guy said it worked absolutely awesome and he had done a half dozen of them with the FMJ front crossmember, said it was THE way to go. The guy who did it had tried Dakotas under these cars. He said the FMJ conversion was much preferred ...?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2498986
05/22/18 11:15 AM
05/22/18 11:15 AM
Old Ray
Guy said it worked absolutely awesome and he had done a half dozen of them with the FMJ front crossmember, said it was THE way to go. The guy who did it had tried Dakotas under these cars. He said the FMJ conversion was much preferred ...? .....if it's that great why is it for sale ?
[Re: Old Ray]
#2499201
05/22/18 08:29 PM
05/22/18 08:29 PM
CrAzYMoPaRGuY
Canada
Guy said it worked absolutely awesome and he had done a half dozen of them with the FMJ front crossmember, said it was THE way to go. The guy who did it had tried Dakotas under these cars. He said the FMJ conversion was much preferred ...? .....if it's that great why is it for sale ? ??? It was an unfinished car, no engine and trans. He said the fifth or sixth car he had done with the FMJ clip. He thought the best swap as far as he was concerned. Why was he selling it? Never asked. You mean it's not good and he was lying because he was selling it or....? He had a 1957/1958 Plymouth in Abbotsford. It was on Kijjiji for a month or so....
CrAzYMoPaRGuY
[Re: Old Ray]
#2499235
05/22/18 10:25 PM
05/22/18 10:25 PM
poorboy
Freeport IL USA
Old Ray,When I moved the motor & trans back on the Dakota frame in my coupe, I bolted in a 1/4" thick plate to the frame (on each side) where the original motor mount bracket bolted to, and then drilled holes and bolted the motor mount brackets to the 1/4" plate. Well then I must be doing the right thing because that is exactly what I am doing. Mostly by accident, the only plate I had that was big enough was some 1/4 inch. I did the pass side this morning, drivers side tomorrow, did you gusset or put any extra reinforcement on, especially on the drivers side? There is one extra threaded hole on the drivers side that I will use as well. Thanks for the advice, much appreciated. Actually, I will have to get under the car and look. I believe I may have added a little extra support on the driver side, but its been 6 years since I did it. The bottom line is, if you think it should have extra bracing there, you need to add it. That sort of things tends to give a guy more confidence, and that often results in driving the car more. More driving adds to the pleasure of owing an old car/truck, and that is why we do this in the first place. Gene
[Re: poorboy]
#2499269
05/22/18 11:43 PM
05/22/18 11:43 PM
CrAzYMoPaRGuY
Canada
CrAzYMoPaRGuy, I suppose there may be advantages in cutting everything off the front and building mostly new. It can't be much worse dealing with the obsolete FMJ crossmember then its getting to be dealing with the 25+ year old 1st gen Dakota.
I was surprised how few choices of some parts (like brake pads) were available for the 5 bolt Dakotas a few weeks ago, when I bought the stuff for my new project. Gene I have a 1995 Dakota for a donor chassis. I just bought brand new 5 bolt hubs and rotors for it without any problem. Don't know which way I'm going but parts where I am seem pretty easy to find honestly
CrAzYMoPaRGuY
