440 A body throttle cable setup #2498456
05/21/18 12:22 AM
05/21/18 12:22 AM
Fort Collins, Colorado
CoDart Offline OP
CoDart  Offline OP
I was wondering what everyone is using for throttle cable setups on a 440 Abody?
My issue now is that the cable is super close to the valve cover and that the pedal has a lot of resistance. Any input to a nice new setup would be great 👍
Re: 440 A body throttle cable setup [Re: CoDart] #2498607
05/21/18 12:18 PM
05/21/18 12:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did you use stock mounts or ears?
Re: 440 A body throttle cable setup [Re: CoDart] #2498760
05/21/18 08:01 PM
05/21/18 08:01 PM
was this a regular SB cable?
Re: 440 A body throttle cable setup [Re: CoDart] #2498792
05/21/18 09:39 PM
05/21/18 09:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine is fine, close, but works smoothly. Different (taller) intake & aftermarket bracket, though.
Looks like you have a plastic oil pressure line; I'd recommend you run a metal line instead.
Re: 440 A body throttle cable setup [Re: topside] #2498810
05/21/18 10:30 PM
05/21/18 10:30 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Wrong length cable, and it should be further up towards the front of the engine. Using a Holley carb is also an issue. Most people go to a completely aftermarket set-up.
JB Rhinehart, Realist
A-Body's RULE!
Re: 440 A body throttle cable setup [Re: CoDart] #2499206
05/22/18 08:43 PM
05/22/18 08:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Was it a 6 cylinder car, cable does look to long. Find a V8 cable if so
Re: 440 A body throttle cable setup [Re: CoDart] #2499240
05/22/18 10:49 PM
05/22/18 10:49 PM
AndyF Offline
AndyF  Offline
Buy and adjustable bracket that lines up properly. Mancini Racing and Hughes Engines carry them. Been around for 20 years........
Re: 440 A body throttle cable setup [Re: AndyF] #2499334
05/23/18 02:28 AM
05/23/18 02:28 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree Cable looks fine. If we had a side shot I would bet the resistance is coming from the different heights of the bracket and carb linkage. Mancini has a good one.
