80's style HVAC case in a 70's pickup ? #2498365
05/20/18 08:36 PM
05/20/18 08:36 PM
Guitar Jones Offline OP
Has anyone done this? Looking at options to install A/C in my 74. What about the entire dash assembly as well? Not really what I want to do but it may be an option.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 80's style HVAC case in a 70's pickup ? [Re: Guitar Jones] #2498511
05/21/18 03:34 AM
05/21/18 03:34 AM
ND
dodgedon Offline
dodgedon  Offline
ND
Not really what you are asking but i installed a 90 system into an 85 crew cab. But these trucks are the same on the inside. The opening on the fire wall is different on your 74.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 80's style HVAC case in a 70's pickup ? [Re: Guitar Jones] #2498519
05/21/18 05:08 AM
05/21/18 05:08 AM
Yeah I know the firewall opening is different but that isn't any thing some sheet metal can't take care of.
Re: 80's style HVAC case in a 70's pickup ? [Re: Guitar Jones] #2498523
05/21/18 07:51 AM
05/21/18 07:51 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I sort of did this, just heat though on an 80.
The box fit the firewall and kick panel without much effort.
But the 81 up ducts are molded to fit the 81 up dash, vs hose for the 70's stuff. So...
I swapped the newer dash, which I don't recommend. The only holes that lined up were under the windshield. The lower corner bolts are nowhere near the right spot and the steering column mount is slightly higher on the older truck.
Then there's wiring, the newer ammeter is not compatible with the older wiring.i ended up swapping the wiring harness as well which has a different bulkhead connection.
Remember, this was heat only, ac probably adds more headache.
Angry white pureblood male
Re: 80's style HVAC case in a 70's pickup ? [Re: Guitar Jones] #2498551
05/21/18 10:22 AM
05/21/18 10:22 AM
scratchnfotraction Offline
I am pulling an Hvac system out of an 86 truck cab next weekend if you want it. I will donate it.
I will be blocking off the hole so we could also cut a piece out to get the correct hole to bolt into your 74 once you cut a patch out of it. then just graft it in place.
I had a 79 4x4 that I junked a while back and it had a mid 80s dash installed in it.
IIRC, they bolt in the same bolt locations only the frame/cover/harness changed. **** I did not look at it that close enough to remember how it was in there.
mid 80s has the 2 lower side bolts/ one bracket in the middle/ and screws across front edge under gasket.
Re: 80's style HVAC case in a 70's pickup ? [Re: Guitar Jones] #2498881
05/22/18 12:55 AM
05/22/18 12:55 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Way back I took the a/c unit from a 75 a/c truck and installed it in my 77 non a/c truck. I cut the 3 dash openings and the controls fit fine. As I remember the cowl was the same. You just about need the windshield removed to do the dash frame swap. 72-80 would be a shoe in. 81 and newer everything is different.
Re: 80's style HVAC case in a 70's pickup ? [Re: scratchnfotraction] #2499844
05/24/18 04:49 AM
05/24/18 04:49 AM
That would be awesome Mike. It would give me an excuse to come up and visit with you as well. Just let me know. Thanks.
Re: 80's style HVAC case in a 70's pickup ? [Re: Guitar Jones] #2499870
05/24/18 09:47 AM
05/24/18 09:47 AM
any time you are ready. I have the cab on a trailer at the house now. I will be stripping stuff off this weekend.
off work Friday & Monday this weekend.
