80's style HVAC case in a 70's pickup ?
#2498365
05/20/18 08:36 PM
05/20/18 08:36 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Has anyone done this? Looking at options to install A/C in my 74. What about the entire dash assembly as well? Not really what I want to do but it may be an option.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 80's style HVAC case in a 70's pickup ?
[Re: Guitar Jones]
#2498511
05/21/18 03:34 AM
05/21/18 03:34 AM
Posts: 516 ND
dodgedon
ND
Not really what you are asking but i installed a 90 system into an 85 crew cab. But these trucks are the same on the inside. The opening on the fire wall is different on your 74.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: Guitar Jones]
#2498519
05/21/18 05:08 AM
05/21/18 05:08 AM
Guitar Jones
Yeah I know the firewall opening is different but that isn't any thing some sheet metal can't take care of.
[Re: Guitar Jones]
#2498523
05/21/18 07:51 AM
05/21/18 07:51 AM
Posts: 5,777 ohio
ruderunner
ohio
I sort of did this, just heat though on an 80.
The box fit the firewall and kick panel without much effort.
But the 81 up ducts are molded to fit the 81 up dash, vs hose for the 70's stuff. So...
I swapped the newer dash, which I don't recommend. The only holes that lined up were under the windshield. The lower corner bolts are nowhere near the right spot and the steering column mount is slightly higher on the older truck.
Then there's wiring, the newer ammeter is not compatible with the older wiring.i ended up swapping the wiring harness as well which has a different bulkhead connection.
Remember, this was heat only, ac probably adds more headache.
Angry white pureblood male
[Re: Guitar Jones]
#2498551
05/21/18 10:22 AM
05/21/18 10:22 AM
Posts: 15,487 Florida
scratchnfotraction
I am pulling an Hvac system out of an 86 truck cab next weekend if you want it. I will donate it.
I will be blocking off the hole so we could also cut a piece out to get the correct hole to bolt into your 74 once you cut a patch out of it. then just graft it in place.
I had a 79 4x4 that I junked a while back and it had a mid 80s dash installed in it.
IIRC, they bolt in the same bolt locations only the frame/cover/harness changed. **** I did not look at it that close enough to remember how it was in there.
mid 80s has the 2 lower side bolts/ one bracket in the middle/ and screws across front edge under gasket.
[Re: scratchnfotraction]
#2499844
05/24/18 04:49 AM
05/24/18 04:49 AM
Guitar Jones
mid 80s has the 2 lower side bolts/ one bracket in the middle/ and screws across front edge under gasket. That would be awesome Mike. It would give me an excuse to come up and visit with you as well. Just let me know. Thanks.
