Small block Chevy Thermostat Housing fits small block Mopars #2498376
05/20/18 09:01 PM
05/20/18 09:01 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
I'm pretty sure a small block Chevy Thermostat housing fits the small block Mopar manifolds ….right??
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498377
05/20/18 09:10 PM
05/20/18 09:10 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
Found my answer...
https://www.speedwaymotors.com/Chevy-Mopar-Chrome-Water-Neck-Gasket-Sealed,7074.html
On Speedway…...
Chevy/Mopar Chrome Water Neck, Gasket Sealed
Chevy Small Block V8, Chrysler Small Block V8, Chrysler Big Block V8, Chevy Inline Six, Zinc
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498384
05/20/18 09:28 PM
05/20/18 09:28 PM
Always a good day when you can solve your own problems! If it is chromed on the bottom sealing surface I would suggest drawfiling the chrome off of there & not torqueing the 2 bolts too hard which can warp it & make it leak. the sealing surfaces are too narrow.
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498387
05/20/18 09:44 PM
05/20/18 09:44 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498446
05/20/18 11:48 PM
05/20/18 11:48 PM
that looks like a nice piece, pricey tho. I've had some problems getting em to seal, I think I was torqueing the bolt too tight & warping it a bit. A thin gasket with some of "the right stuff" cement ended up doing the trick. I wish the sealing surfaces on housings were a bit wider.
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498507
05/21/18 03:13 AM
05/21/18 03:13 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
wow. CVR makes nice stuff.
They even have -16 AN straight or 90 deg housings.
I've always used Hylomar and had no leaks.
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498547
05/21/18 10:18 AM
05/21/18 10:18 AM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
It is a very nice looking piece.....Sits right smack in the middle of the bay as you open the hood...….makes a nice addition......
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Fabman] #2498606
05/21/18 12:13 PM
05/21/18 12:13 PM
Norfolk, NE
Racer33 Online content
Racer33  Online Content
Norfolk, NE
Chevy stat housings fit but aren't the same. Mopar has a recess in the housing for the stat. Chevy has a recess in the intake for the stat. Using a chevy stat housing on a mopar intake leaves you know place for the stat to sit.
Re: Small block Chevy Thermostat Housing fits small block Mopars [Re: Racer33] #2498678
05/21/18 04:17 PM
05/21/18 04:17 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I believe Racer33 is correct about the Chevy and Mopar NOT interchanging. I think this is the one you want.
https://www.summitracing.com/parts/cvs-tsh8bk/overview/make/chrysler
