How to remove broken idle adjustment screw in six-pack carb? #2498396
05/20/18 10:05 PM
05/20/18 10:05 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
One of my idle adjustment screws was frozen in place, so I soaked it with PB Blaster. Unfortunately, I still broke it trying to get it out. panic Is there an accepted method for getting it out without damaging anything? Thanks for any suggestions.
Roger
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2498427
05/20/18 10:53 PM
05/20/18 10:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Check this out
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2498430
05/20/18 11:01 PM
05/20/18 11:01 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Scott, You are worth every dime we should be paying you!
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Vert] #2498457
05/21/18 12:25 AM
05/21/18 12:25 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks very much, Scott. So, there's no problem with leaving the hole there? I suppose it will be covered by the gasket, so should not leak(?).
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2498470
05/21/18 12:46 AM
05/21/18 12:46 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually drilling doesn't solve the problem,the broken threaded part is the problem,still there and not easy to remove.If you try drilling,you have about one chance in ten of drilling dead center without a jig and if you don't then you end up drilling the threads.At that point the alternative is make a new insert for the base.
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2499321
05/23/18 01:44 AM
05/23/18 01:44 AM
Chicago
PurpleBeeper Offline
Chicago
62max has a good idea, but I actually had this problem myself about 2 yrs. ago & used Scott's drill method & a propane torch I believe and was able to get the outboard idle screw out. It may have helped that I'd only broken off half the head of the screw.
My 2-cents.... try the drill method & if that fails, go with 62max's idea. What do you have to lose?
Hey 62max....HOW DID YOU MAKE THAT NEW INSERT.... I (we) are all ears.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2499377
05/23/18 10:07 AM
05/23/18 10:07 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
fortunately I had access to an EDM machine when one broke off.
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2499385
05/23/18 10:39 AM
05/23/18 10:39 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I ended up doing what 62 max did. I drilled out broken screw part. Then enlarged it to 1/4" (used slight undersize ream from McMaster Carr. Inserted 1/4 aluminum rod about 1/2" if I recall. drilled and tapped for new screw. I ended up having to do all four. I had one that was ever so slightly off center, but didn't seem to affect performance. At least as good as I had the tune I could get.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: RoadRunner] #2499556
05/23/18 04:56 PM
05/23/18 04:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
A little addition if you try to remove broken screws by yourself.First thing you need to do is get rid of the old cork seal,either heat or pick it out.The seal is the creator of the problem,over the years it turns rock hard and makes removing almost impossible without breaking.If I get three sixpack set to do I can guarantee at least two broken screws minimum.Also if you choose to drill,a small end mill is almost a necessity,unless you have a perfectly flat surface to drill,the drill bit will walk and not center.Once I get them drilled,I use a small center punch with the end squared,tap it into the hole and back the screw out,picture attached.
Re: How to remove broken idle adjustment screw in six-pack carb? [Re: Fab64] #2499801
05/24/18 01:28 AM
05/24/18 01:28 AM
Chicago
Chicago
I like this drill, square punch idea.
